Camshafts
Old September 23rd, 2023, 01:00 PM
Wally's Avatar
Camshafts
I picked up three camshafts that are all supposed to fit my 1958 371.
One Engle, one Isky, and one Crane. Couldn't pass up the deal on them.
Now I need help identifying them.
I've found a page from the old Engle catalog but if anyone has pages from the old Isky and Crane catalogs it would really be appreciated!
Thanks, Wally
Wally is offline
Old September 23rd, 2023, 02:19 PM
OLDSter Ralph's Avatar
Walt. here is a 1961 Isky Catalog.
OLDSter Ralph is offline
Old September 23rd, 2023, 02:26 PM
Wally's Avatar
Turns out the Engle is a 153 and it doesn't show up on my page from the Engle catalog. Only goes up to 151.
Does anyone know what an Engle 153 is?
Wally is offline
Old September 23rd, 2023, 02:37 PM
Walt. here is what I found about the Engle 153. 282 & 288 advertised duration, about .500" lift.
https://www.jalopyjournal.com/forum/...ds-cam.237381/
Old September 23rd, 2023, 02:49 PM
Wally's Avatar
Thanks Ralph, It looks like the Isky cam and the Crane cam got swapped in their tubes.
What I thought was the crane cam is marked RR2 which would make it an Isky cam unless they both used the same terminology.
This looks like what I'm going to use in the 371 (Now 382)
Once I identify the other two cams they're probably going up for sale.
Wally is offline
Old September 23rd, 2023, 02:55 PM
Wally's Avatar
Again, Thanks Ralph, It looks like the Engle cam would give me about .445 lift if I use the stock rockers. 1.6 versus 1.8 ratio.
Now it's a toss up between this one and the Isky cam. Either one should give me what I'm looking for in the 382.
Wally is offline
Old September 27th, 2023, 08:11 AM
Wally's Avatar
Ralph, it's strange the Isky cam doesn't reflect any of those numbers.
This is what is stamped in the end:
Z69 2P 08 59 302 HYD
Are you sure that is the page from the Isky catalog?
Wally is offline
Old September 27th, 2023, 10:41 AM
Wally, I am wondering if that page is only "Roller cam" stuff, now that I read more closely. The guy who originally posted it had a roller cam in a J-2 he bought. If I can remember his name, I'll see if the catalog has other pages for hydraulic and solid lifter cams.
The only thing I can pick out, is that its a 302 degree hydraulic lifter camshaft. Are you sure its an Isky cam ?
Old September 27th, 2023, 12:56 PM
Wally's Avatar
Ralph, it has Iskenderian stamped on the end so I'm pretty sure it's an Isky cam.
Wally is offline
Old September 27th, 2023, 04:21 PM
BillK's Avatar
Call Isky. They are still in business and can tell you exactly what it is.
What numbers are on the cam that you think might be Crane ?
BillK is offline
Old September 27th, 2023, 05:16 PM
Wally, ok, thats proof enough for me. Will the 302 degree cam be a bit much for use with a Hydramatic ?
I contacted ncboat about the cam page he posted and he might have other cam pages for hydraulic and solid lifter cams. I think he told me it was a "pre 60's" cam catalog from Isky.
BillK, great idea about calling Isky. (310) 217-9232.
Old September 27th, 2023, 05:32 PM
Wally's Avatar
Bill,
The Crane Cam has two numbers on it: 30837 and 9136
That's all I know.
Wally
Wally is offline
Old September 27th, 2023, 07:11 PM
Crane cams is no longer in business, as I recall. Seems like they were merged into CompCams. Cutlassefi knows the details, I think.
Old September 29th, 2023, 04:03 AM
BillK's Avatar
Bill,
That's all I know.
Wally
I guess my 2005 catalog isnt old enough Nothing for the older Olds engines at all.
If the engine is out of the car it would be easy enough to put each cam in it with a degree wheel and figure out exactly what it is.
BillK is offline
Old October 8th, 2023, 04:27 PM
ncboat's Avatar
RR2 is a roller designed to be used with 1.5 adjustable rockers. Has 440 lift with 1.5, would be approximately 528 with 1.8. A set of Isky 1.5 adjustable rockers just sold for over $700 on EBAY. Then you need ,921 roller rockers or sleeve the lifter bore and run Chevrolet rollers. Trust me I know, now have everything for my RR3 cam that came in my engine.
RR2 intake 24 -64 exhaust 62 - 26 440 lift
ncboat is offline
Old October 9th, 2023, 04:33 AM
Wally's Avatar
Thanks for the information. That is what I suspected. Probably more than I want to spend on my engine.
Wally is offline
Old October 9th, 2023, 06:27 AM
ncboat's Avatar
Talk to Hunter at Camcraft and see if he can regrind for hydraulic.
ncboat is offline
Old October 9th, 2023, 06:39 AM
Wally's Avatar
I thought about that, I have a local guy that might be able to do just that. He is always busy though, get's cam work from all over the country.
Wally is offline
Rocketbrian
November 19th, 2023 09:23 AM
Rockie Collins
March 18th, 2021 06:15 PM
57olds371
May 17th, 2018 08:35 AM
trochte@comcast.net
September 26th, 2010 12:53 PM
Rabbit
February 12th, 2007 10:53 PM
Quick Reply: Camshafts
