E heads
Old September 3rd, 2012, 11:26 AM
LI Olds's Avatar
E heads
can someone explain to me the difference in heads?
what was standard on a 69 cutlass?
what advantage would one gain by adding an "E" head to the original 350 engine?
LI Olds is offline
Old September 3rd, 2012, 12:16 PM
firefrost gold's Avatar
THe E head is for a BBO You can use them but yopu would have to go with a performer rpm intake for the sbo and then do some head work or piston changes to get the compression right . Not a bolt on and go deal.
firefrost gold is offline
Old September 3rd, 2012, 03:11 PM
Small block Olds heads carry an identification number, big block heads use a letter. The big block heads have larger ports, larger valves, and usually larger combustion chambers than the small block heads. They do bolt on, however as noted above unless the engine is modified to take advantage of the big block head, you will actually hurt performance due to the compression ratio drop and the mismatch in the intake ports that will cause a flow disruption. Bolting E heads onto an otherwise stock 350 is a waste of time and money.
joe_padavano is offline
64 CUTLASS KEN
December 7th, 2020 06:43 AM
olds4life
December 25th, 2012 12:56 AM
Oldsmaniac
November 1st, 2010 06:37 PM
gearheads78
November 10th, 2009 09:31 PM
DarkStar
October 21st, 2009 07:35 AM
Quick Reply: E heads
