Edelbrock Carb Vacuum Lines
Old May 14th, 2008, 10:05 AM
#1CutlassSupreme's Avatar
Question Edelbrock Carb Vacuum Lines
So I just got my new Edelbrock Thunder Series 650CFM Carb and my Performer Intake. (Freakin' excited like christmas here!!)
Anyway, on the back side of the carb there is a vac port that can be used for the power brake booster, but there is also a port on the intake manifold just like on the stock 350 Olds intake.
Any suggestions on which one is best to hook into or if there is an advantage one way or the other? More vac on the carb vs. the manifold?
I'm running a bit bigger cam and I'm doing a 4-wheel power disc brake conversion with a new booster and new master cylinder. So what I gather from an earlier post is that I'll need as much vac as I can get (Btw; the car currently has stock front disc brakes.)
Thanks!
#1CutlassSupreme is offline
Old May 14th, 2008, 02:14 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I'd run manifold vacuum.
J-(Chicago) is offline
Old May 14th, 2008, 03:02 PM
There's absolutely no difference. They both provide manifold vacuum. Just pick one and cap the other.
joe_padavano is offline
Old May 14th, 2008, 04:28 PM
Kinda figured they were bout the same, but wasn't sure if one beling closer to the head had more or less vac than the other.
Thanks again.
alwayssomething
January 29th, 2010 06:52 PM
StarfireFox62
September 25th, 2008 01:29 PM
terribleonexx88
March 16th, 2007 12:00 PM
Chumley
January 3rd, 2007 06:00 AM
bbock
June 5th, 2006 11:50 AM
Quick Reply: Edelbrock Carb Vacuum Lines
