Flat Top or dish? Looking to boost compression!!
Old June 10th, 2010, 01:37 PM
nuttkaze's Avatar
To make a long story short I called summit to see what they had to boost my compression up in my original 4 barrel 71' cutlass witha 350.
I told him I'm going with:
Clean up heads and go with 2.00 intake valves
Headman Headers
Eaton Posi w/3.36 gears
Rebuild my Quad Jet Carb
Edelbrock 7111 Intake
442 Air cleaner
MSD Ignition
I will choose cam after I know my compression, but I'm shooting for 9.5
He recommend TRW Speedpro Forged Dish Pistons then my phone disconnected and when I called back they were close...that was last night.
I wondering why he didn't recommend the TRW Speedpro Forged Flat Top
http://www.summitracing.com/parts/TRW-WL2320F/
What will be my compression if I went with the dish pistons vs. the flat top pistons?
nuttkaze is offline
Old June 10th, 2010, 06:29 PM
cutlassefi's Avatar
Can't really answer that, need to know head cc, deck height etc. but typically the flat top will give you about a half point or better over the regular dish.
cutlassefi is offline
Old June 10th, 2010, 07:14 PM
X2, it depends on actual measurements, but as a ballpark assessment, the 68-70 W-30 motors with steel shim head gaskets and 64-ish CC chambers were factory rated at 10.5:1. Of course, production tolerances can change that, and using the thicker FelPro blue head gaskets will lower it.
joe_padavano is online now
Old June 10th, 2010, 07:40 PM
svnt442's Avatar
Joe did you mean W31?
svnt442 is offline
Old June 11th, 2010, 07:31 AM
Yeah, sorry. I'm kinda big-block-centric...
Old June 12th, 2010, 03:12 PM
Warhead's Avatar
Too bad these heads came with a 68-70cc chamber from the factory.
Factory rating, and production pieces, are sometimes two different monsters.
It will take at least a .030" cut to get to the 64-65cc chambers. Then cut another .020" to account for the gaskets.
Then you might be at the 10.5:1.
If you skip the milling, you will be much closer to your target, IMHO.
Jim
Warhead is offline
greenslade
March 29th, 2011 03:56 PM
Jamesbo
January 21st, 2010 05:23 AM
455islove
October 10th, 2009 09:30 PM
cfair
September 13th, 2009 05:00 AM
cts-v
January 10th, 2009 04:55 PM
Quick Reply: Flat Top or dish? Looking to boost compression!!
