Fuel Pressure 1970 Cutlass Sumpreme 350
Old December 6th, 2011, 12:28 PM
70Cutlass_408's Avatar
This weekend I got around to installing a Edelbrock Performer RPM intake, Holley 670 Street Avenger, new Carter Muscle car fuel pump and fram inline fuel filter.
When I first fired up the car the fuel pressure was very low almost non existent according to the fuel pressure gauge. It stayed like this all day when I was driving around town.
The next day I fire up the car and checked the fuel pressure gauge and its reading about 5 psi. Could I have a faulty fuel pressure gauge, clogged fuel lines, bad fuel pump?
Thanks,
70Cutlass_408 is offline
Old December 6th, 2011, 12:40 PM
svnt442's Avatar
5 psi sounds about right. If your pressure was non existent the car wouldn't run. I'd keep an eye on it and see what happens. It may have been stuck from sitting and just took a bit for it to free up.
svnt442 is offline
Old December 6th, 2011, 01:03 PM
thanks Randy, the car was sitting for about a month before I decided to work on it this past weekend.
Old December 7th, 2011, 05:49 PM
So today i fired up the cutlass and now the fuel pressure guage is reading 3 psi. Any suggestions on what might be causing the sporatic fuel pressure.
thanks,
Old December 7th, 2011, 07:09 PM
If the car is running fine, I'd stop looking at the gauge.
MDchanic is offline
Old December 7th, 2011, 07:15 PM
Chevy budget Olds powered
coppercutlass's Avatar
x2 with mdchanic. I had a pressure gauge bounce between 5 and 10 all day long but the fuel bowl levels stayed the same drove fine so i left it alone.
coppercutlass is offline
Old December 8th, 2011, 07:49 AM
Ok thanks guys
Old December 19th, 2011, 10:34 AM
I ended up changing the fuel filter and now fuel pressure is reading 6.5 psi all day.
dnmfranco
November 14th, 2013 05:04 PM
oldsuniversew30
April 22nd, 2013 05:03 PM
pcard
March 15th, 2013 12:44 PM
foreverolds
December 1st, 2012 07:07 PM
glord
July 21st, 2009 11:23 PM
Quick Reply: Fuel Pressure 1970 Cutlass Sumpreme 350
