gauges help help help
Old April 14th, 2010, 05:21 PM
MJAKS462's Avatar
Ok guys I am hooking up autometer water , volt , and oil gauges. I have the water temp sender bolted on the rear of the edelbrock intake manifold ( Is this OK spot)
The oil pressure sender I was going to hook up just to the left of the engine numbers just behind the water pump because there is a port there and that is where the old mechanical one was ,but it does not fit there because it is an elec. gauge and has a huge sender.
So my ? is , is on the intake manifold ok for water temp and where is another pressure port that I can put the oil pressure sender ?
MJAKS462 is offline
Old April 14th, 2010, 07:46 PM
ozoneblue's Avatar
Is the old one light or guage ?
ozoneblue is offline
Old April 14th, 2010, 08:33 PM
this is not my car lol
scubastever's Avatar
i have the same set up.
the water temp sensor goes in the front of the intake. the oil pressure sender might need to be plumbed with some pipe though. head over to the any auto parts store and be sure to get the correct thread pitch! the oil sensor goes in that hole beside the casting #'s.
be careful not to KINK or BEND either the oil pressure nylon hose, or the temp sensor copper pipe.
scubastever is offline
Old April 15th, 2010, 03:51 AM
MJAKS462's Avatar
these are electric so no nylon hose , the oil sender is huge so it dont fit next to the casting # unless I raised it about an inch , So you are saying plumb the sender port with a piece of pipe in order to raise the sender up to clear obstructions ?Will it still be accurate and everything ?As far as the water temp I guess I will leave it at the rear of the intake instead of moving it to the front.
MJAKS462 is offline
Old April 15th, 2010, 10:46 AM
To expand on the prior posts, first the coolant sender needs to be in an area of flowing coolant. The port at the back of the intake is a dead end, which can lead to incorrect temp readings. The sender should be installed in one of the bungs in the coolant crossover at the front of the intake, adjacent to the t-stat.
The oil pressure sender, on the other hand, does want to be at the end of a pipe. Even the factory used a section of pipe to raise the sender high enough to clear. I use a 2" section of 1/8" NPT nipple with a coupler. The factory part, which is available as a repro, is actually a section of pipe with an integral 45 deg elbow at the end for the sender. You can replicate this with hardware store parts if you care about appearances.
joe_padavano is offline
Old April 15th, 2010, 02:34 PM
MJAKS462's Avatar
Ok thanks alot
MJAKS462 is offline
westside807
June 22nd, 2015 09:21 PM
MJAKS462
April 15th, 2010 04:00 AM
citcapp
December 14th, 2009 11:10 AM
ct1979
January 9th, 2007 09:17 PM
skibone
April 15th, 2004 03:13 AM
Quick Reply: gauges help help help
