Help with rocker studs
Old May 12th, 2016, 10:01 PM
80olds's Avatar
I recently ordered a set of springs from lunati, the 73195 springs. They said the springs set up at 1.7 inches. Since im going to a adjustable valve train would rocker studs that have a effective stud length of 1.52" inches work, or would i need some a bit longer to be more level with the top of the spring? Also, will 302 roller rockers work on oldsmobile heads? Thanks!
80olds is offline
Old May 13th, 2016, 06:40 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Yes, they will. I am currently running Scorpion SBF 1.72 ratio rocker arms. I was looking for maximum lift. Comp makes a conversion stud if the threads are 5/16" or you can by the Olds specific rocker arms.
olds 307 and 403 is offline
Old May 13th, 2016, 02:07 PM
80olds's Avatar
Thanks, helps me a lot. Do you have any clue on which rocker studs I'm gonna need?
80olds is offline
Old May 13th, 2016, 05:45 PM
These if the heads haven't been drilled for over sized studs.
http://m.summitracing.com/parts/cca-4542-16#
Old May 13th, 2016, 06:48 PM
80olds's Avatar
Thanks so much! You're a life saver
80olds is offline
CutlassLegend
September 21st, 2011 02:56 PM
330noob
August 30th, 2011 10:07 PM
The Swede
June 3rd, 2011 02:05 AM
defiant1
March 31st, 2011 04:28 AM
sx455raidercelticfan
January 10th, 2011 12:57 PM
Quick Reply: Help with rocker studs
