I need a better fan
Old October 18th, 2017, 09:08 AM
garage goat2's Avatar
I need a better fan
I have a 1987 Salon with a 355 SBO in it thats built. This engine came out of my wrecked 1985 442.
I had a pickup truck's fan on it at the time yet it was destroyed in the accident.
And I have no records of the part # on file ( this was 10 years ago)
The fan that was destroyed Had very strong suction, yet the stock one I have now is a wuss!
Would anyone have a part # I could check on ?
I might load the car with tools and go to some yards nearby. And see if they have any trucks or vans in them.
Thanks for any help
garage goat2 is offline
Old October 18th, 2017, 12:29 PM
Electric or mechanical?
Fun71 is offline
Old October 18th, 2017, 06:06 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
You need either a factory 6 or 7 blade fan with the extra heavy clutch or the fixed 4 blade fan like the factory fan on my 70.
olds 307 and 403 is offline
Old October 18th, 2017, 06:11 PM
Chevy budget Olds powered
coppercutlass's Avatar
I have dual 9c1 caprice fans. Im running a stout sbo that runs 12.20's i drive it to the track and back and it will idle all day in traffic no issues. Just fwiw. The stock set up worked but this set up frees up hp
coppercutlass is offline
Old October 19th, 2017, 05:58 AM
I have a new clutch on it yet I need more fan blades
Old October 19th, 2017, 06:26 AM
Does your car overheat or is it just that you don't like the fans on it now?
Olds64 is online now
Old October 19th, 2017, 07:34 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I seem to remember the Ford Windstar fan is a popular electric fan from the junkyard. I have not used one though.
redoldsman is online now
Old October 19th, 2017, 07:43 AM
Yes to both, I can,t run the AC without it going up to 230.
Old October 19th, 2017, 07:46 AM
Do you have the fan shroud and upper and lower air dams installed correctly?
Old October 19th, 2017, 03:41 PM
Olds Fever
CRUZN 66's Avatar
I have several different 6/7 blade fans from various engines that I have removed over the years... I will try to take a few photos this weekend and post them... Possibly one will look like your old fan that was damaged...
CRUZN 66 is offline
Old October 20th, 2017, 07:35 AM
Thanks Do they have more blades than a factory 307 style would have?
Old October 20th, 2017, 08:25 AM
brownbomber77's Avatar
If you're going through this trouble once, just get a factory Camaro, Windstar, or newer GM truck fan and shroud. There's so much space after you remove the mechanical fan.
brownbomber77 is offline
Old October 20th, 2017, 03:54 PM
Olds Fever
CRUZN 66's Avatar
They have 6 or 7 blades as I mentioned in my post...
CRUZN 66 is offline
Old October 22nd, 2017, 05:07 AM
I went out and counted the blades, Yup there is seven of them.
Old October 22nd, 2017, 03:21 PM
Olds Fever
CRUZN 66's Avatar
Checked my stock and I don't have any 7 blade fans left, mostly all 5-Blades but different styles...
CRUZN 66 is offline
Bee Saint Louis
July 5th, 2019 08:58 PM
convertible 63
May 9th, 2018 06:10 AM
ostie13
Brakes/Hydraulic Systems
17
June 29th, 2016 03:52 PM
agtw31
June 23rd, 2009 01:39 PM
esisson
May 20th, 2008 12:09 PM
Quick Reply: I need a better fan
