Loose balancer
Old April 28th, 2011, 08:00 PM
455man's Avatar
Loose balancer
Years ago I had a problem with my harmonic balancer not staying tight on my 455. Thought it was a bad balancer. Now I have a 350 that I just got running after years of sitting and noticed the harmonic balancer is loose. Is this common for olds or just for me?
Anyway, anyone know the size of socket it takes? I always had to borrow the neighbors now I have to go buy my own.
455man is offline
Old April 28th, 2011, 08:06 PM
2blu442's Avatar
There's been a couple threads saying that the dorman aftermarket balance may not fit tight. I wonder if you have one of those?
I believe the socket is 1 1/4" but am not positive. If nobody else knows I'll check a motor in the garage tomorrow and find out for sure. John
2blu442 is offline
Old April 28th, 2011, 08:14 PM
oldsfromyell's Avatar
1 1/8th socket for the balancer bolt. torque is 180ft.lbs if memory serves.If the balancer has been run loose you will need to mic the crank snout and balancer bore to make sure they are in spec. If the balancer bore is oversize you will need another one. If the crank snout is worn you are probably looking at getting another crank. Just my .02
oldsfromyell is offline
Old April 29th, 2011, 06:32 AM
455man's Avatar
I dont think It's an aftermarket balancer. The car had been sitting for years. I just fired it up and was surprised it ran. I'll check the balancer and crank.
455man is offline
kyleg
Ninety-Eight
June 11th, 2016 04:32 PM
silverriff
January 21st, 2010 03:54 PM
ztim
July 10th, 2009 05:28 PM
scrappie
April 9th, 2008 05:12 PM
Old Whitey
November 25th, 2006 08:19 PM
Quick Reply: Loose balancer
