Need .040 mains on a 330
Old May 5th, 2023, 03:40 AM
Kirdid's Avatar
So my machinist thought it practical to have rods and mains in the same undersize so he ground both to .040 and now my rare 330 crank is useless since i can’t find a single place that sells or ships .040 bearings. Do any of you all have any wisdom? Can i grab a stock 403 crank and drop it in?
I really want to keep the 330 crank but at this point it seems like it’s done for.
thanks for any input
Kirdid is offline
Old May 5th, 2023, 04:17 AM
BillK's Avatar
King shows them in 40 for the "second design" engine. Whether they are available or not is another story. MB5514AM .040
BillK is offline
Old May 5th, 2023, 06:44 AM
Kirdid's Avatar
i saw those as well, what does second design mean? No thrust bearing?
Kirdid is offline
Old May 5th, 2023, 07:11 AM
BillK's Avatar
According to the Clevite book the first design had a full groove #1 main. It looks like it was only the first year.
I checked with King and they do not have them and no ETA Federal Mogul and ACL also show them in 40 but have not heard back yet to see if they actually have them.
BillK is offline
Old May 5th, 2023, 07:18 AM
Oldsmaniac's Avatar
There are plenty of 330's around if thats the route you need to go...
Oldsmaniac is offline
Old May 5th, 2023, 08:38 AM
Old(s)GuysRule
67OAI's Avatar
Oldsmaniac, Kirdid is in Norway, there may not be many 330s or for that matter any other Oldsmobile motors available there! I would imagine that shipping a crankshaft from the US would be quite expensive. Kirdid, place a new post in the "Parts Wanted" section of the "Classifieds" for these engine bearings and NO the 403 crankshaft would not be directly useable in a 330 block. The engine bearings are the same but Oldsmobile changed the flywheel flange bolt pattern in 1968 when they introduced the larger bore 350 engine. You would need the crankshaft, flywheel, and harmonic balancer from the 403 (or 350) and most probably would require rebalancing with your piston/rod assemblies.
67OAI is offline
Old May 5th, 2023, 10:12 AM
Kirdid's Avatar
Originally Posted by Oldsmaniac;[url=tel:1496193
1496193[/url]]There are plenty of 330's around if thats the route you need to go...
no, there’s a world outside the US friend
Kirdid is offline
Old May 5th, 2023, 10:15 AM
Kirdid's Avatar
Originally Posted by 67OAI;[url=tel:1496198
1496198[/url]]Oldsmaniac, Kirdid is in Norway, there may not be many 330s or for that matter any other Oldsmobile motors available there! I would imagine that shipping a crankshaft from the US would be quite expensive. Kirdid, place a new post in the "Parts Wanted" section of the "Classifieds" for these engine bearings and NO the 403 crankshaft would not be directly useable in a 330 block. The engine bearings are the same but Oldsmobile changed the flywheel flange bolt pattern in 1968 when they introduced the larger bore 350 engine. You would need the crankshaft, flywheel, and harmonic balancer from the 403 (or 350) and most probably would require rebalancing with your piston/rod assemblies.
ahhh, thank you for the reply! I will do as you have said, and i also sent an inquiry to Egge and asked if they would resize their .060 down to .040 for me and waiting for a reply there. The only olds engines on market here right now are two 403’s that have been beaten to hell it looks like.
Kirdid is offline
Old May 5th, 2023, 01:28 PM
cutlassefi's Avatar
Your machinist owes you a new crank. You never grind or bore ANYTHING until you’re sure what’s available.
cutlassefi is online now
Old May 5th, 2023, 01:46 PM
Kirdid's Avatar
Originally Posted by cutlassefi;[url=tel:1496255
1496255[/url]]Your machinist owes you a new crank. You never grind or bore ANYTHING until you’re sure what’s available.
i totally agree, i just hope i can get this solved without having to go there
Kirdid is offline
Old May 5th, 2023, 02:17 PM
Oldsmaniac's Avatar
Forgive me for not knowing you were from another world, your world would be difficult to source 330 engine parts for sure and even finding a good machinist. We have the same problem here when Chevys are the only thing they know. The disposable cars and engines of today are causing machine shops to close.
Old May 5th, 2023, 02:54 PM
Kirdid's Avatar
yes! That’s precicesly the problem! When i bought the car with the engine rebuilt the parts that were forgotten were the Oldsmobile intricacies you don’t see on the chevy which is probably why they conned it over to someone when they couldn’t get their monster running properly. And machine work here is so damn expensive and even then you could end up with a machinist that is so used to the standard race scene consisting of purely chevy big blocks that he just disregards your wishes. I wanted to work in an engine shop but so few are able to stay afloat as the classic cars turn to dust from the salt.
Kirdid is offline
Old May 5th, 2023, 06:51 PM
BillK's Avatar
Either that or your machinist could cut the crank to .060 for you. My warehouse is still checking on ACL and Sealed Power. If they come up with anything I will let you know.
BillK is offline
Old May 6th, 2023, 02:37 AM
Kirdid's Avatar
Originally Posted by BillK;[url=tel:1496299
1496299[/url]]Either that or your machinist could cut the crank to .060 for you. My warehouse is still checking on ACL and Sealed Power. If they come up with anything I will let you know.
i appreciate that! I’ll cut the crank down to .060 if they can’t resize
Kirdid is offline
Old May 6th, 2023, 02:27 PM
cutlassefi's Avatar
Are you wanting to cut the crank .060 or bore the block .040 or .060? I’m confused.
Old May 6th, 2023, 05:07 PM
BillK's Avatar
Are you wann my tI gvto cut the crank .060 or bore the block .040 or .060? I’m confused.
He would have to cut the crank to .060 because that is the bearings available from Egge if he can't find any .040's. King, ACL and Sealed Power all have .040's in the catalog but nobody seems to actually have them.
BillK is offline
Old May 9th, 2023, 03:45 AM
BillK's Avatar
K,
Just thought I would let you know that I have had no luck finding anything in .040
BillK is offline
Old May 9th, 2023, 03:58 AM
Kirdid's Avatar
Originally Posted by BillK;[url=tel:1496899
1496899[/url]]K,
thank you for getting back to me! I’ll have to go for the .060 Egge mains then
Kirdid is offline
Old May 16th, 2023, 08:45 AM
Kirdid's Avatar
Update!
Nothing to be found, not clevite, sealed power, egge, king, etc. there are no bearings to be found. Which means that for the forseable future i’ll keep my 330 crank for an upgrade later on. I’m looking into a 403 crank that is cheap but then i would have to balance it with the flywheel of my 330 which i don’t know if even works with the added crank weight. Could have bought a crankshaft but the shipping will absolutely ruin me, would’ve cost me 200$ to ship main bearings.
Kirdid is offline
Old May 16th, 2023, 09:06 AM
BillK's Avatar
So Egge didn't have the .060" bearings ? Also read reply #6 above. It sounds like your 330 flywheel might not work on the 403 crankshaft.
BillK is offline
Old May 16th, 2023, 09:25 AM
Kirdid's Avatar
i ordered them and promptly received an email saying they can’t source anything above .020
my line of thought with the 403 would be to buy a harmonic balancer given that i could source a flywheel. I will keep digging
Kirdid is offline
Old May 16th, 2023, 09:49 AM
It definitely won't. The crank flange bolt pattern is different between the 64-67 motors and the 68-90 motors.
joe_padavano is online now
Old May 22nd, 2023, 05:22 PM
BillK's Avatar
Kir,
I found you a set of bearings if you are still interested ?
BillK is offline
Old May 22nd, 2023, 06:55 PM
Kirdid's Avatar
Originally Posted by BillK;[url=tel:1499937
1499937[/url]]Kir,
are you serious?! That’s amazing! I’ll leave my email and you can contact me there. Didrikskarpnesolsen00@gmail.com
Kirdid is offline
The Stickman
July 13th, 2014 07:05 AM
Bernhard
January 6th, 2013 09:27 PM
stoots
October 8th, 2010 05:08 PM
dman0712
December 8th, 2009 09:56 PM
77 oldsMAbrotha
September 23rd, 2008 10:06 AM
Quick Reply: Need .040 mains on a 330
