need help
Old January 29th, 2009, 03:17 PM
ya'll come back now....
Danielle's 71's Avatar
need help
im new to this site i know i have a rocket 350 but where else can i find out info about this motor...casting numbers are 39558
Danielle's 71 is offline
Old January 29th, 2009, 03:26 PM
Registered
Bluevista's Avatar
Welcome. Do you mean #395558? that would be a '73,'74 350 according to the FAQ.
http://oldsjunction.classicoldsmobil...blk.htm#Blocks
Bluevista is offline
Old January 30th, 2009, 06:01 AM
Past Administrator
Oldsguy's Avatar
Welcome to our site. Do you also have a car? Or just an engine?
Oldsguy is offline
Old January 30th, 2009, 06:31 AM
i also have a car and yes i meant 395558...sorry.i was told it was a 70 and some facts i looked at said that also...
Old January 30th, 2009, 07:00 AM
X2
Jamesbo is offline
Old January 30th, 2009, 07:30 AM
Past Administrator
Oldsguy's Avatar
So the engine is newer than the car according to the id number. Not a big deal, may have been replaced by a dealership early on in the car's life.
Oldsguy is offline
Old January 30th, 2009, 07:36 AM
so are all rockets arent big blocks?
Old January 30th, 2009, 07:47 AM
Nope not in Olds speak, but compared to a Honda you would say Yes they are.
But the 350 is a great motor capable of all kind of cool things. It lacks some of the torque of the Big Blocks but don't sell it short by any means.
What kind of car is the motor in?
Does it have a 350 tranny with it?
Jamesbo is offline
Old January 30th, 2009, 09:55 AM
all i know so far is that is has the small block 350 and as far a trans go i have know idea...is there any way to find out how much power it used to have?
Old January 30th, 2009, 10:02 AM
Past Administrator
Oldsguy's Avatar
I think the factory specs were in the high 200s for the 2bbl equipped, maybe 20 hp higher for the 4bbl one. But those numbers really don't mean a lot. I have a reference at home I can look it up for you. 2bbl or 4bbl?
Oldsguy is offline
Old January 30th, 2009, 10:11 AM
im not really sure as to what it is....
Old January 30th, 2009, 10:13 AM
Past Administrator
Oldsguy's Avatar
Take off the air cleaner housing and measure the "hole" in the middle.
Oldsguy is offline
Old January 30th, 2009, 11:57 AM
This is an air clear. [could be red I forget] It is attached with one wing nut so not tools are needed.
Jamesbo is offline
Old February 1st, 2009, 05:17 PM
ok i found out its a 4bbl
Old February 1st, 2009, 06:45 PM
That 350 block casting was used from 1968-1976. The FAQ is wrong, which is why we've fixed it in the Wiki. The VIN derivative on the driver's side of the block will tell the exact year.
joe_padavano is offline
Old February 6th, 2009, 06:05 AM
Junior Member
88 coupe's Avatar
All Olds V8s (except 215) from '49 into the '70s, were called "Rockets".
Except for advertising, the term is useless.
Norm
88 coupe is offline
Old February 6th, 2009, 12:40 PM
Past Administrator
Oldsguy's Avatar
Norm that is true, but I still take pride in referring to my engines as rockets. It's kind of fun.
Oldsguy is offline
Old February 6th, 2009, 02:17 PM
And the 215 was called the "Rockette", so at least someone in the marketing department had a sense of humor.
Old February 6th, 2009, 07:38 PM
jensenracing77's Avatar
even in the 90s, the quad 4 was called Oldsmobile's smallest rockets. your car is a great find. i see a 57 98 running around my town from time to time. trying to locate him but had no luck so far.
jensenracing77 is offline
Old February 8th, 2009, 06:28 PM
well a 455 blot up to my car with eas?
meoff
Site Help
August 29th, 2013 12:15 PM
coppercutlass
March 1st, 2013 07:33 AM
cutlassclay
May 11th, 2012 06:31 AM
MJAKS462
April 15th, 2010 02:34 PM
silverriff
March 24th, 2010 06:36 PM
Quick Reply: need help
