need help on 330 rebuild!!
Old October 30th, 2010, 01:48 PM
330noob's Avatar
So i posted a thread on what i should replace but now my question is where i could find valve train for the 330. any help would be appreciated. i have locked at the local auto parts stores but cant find all the pieces needed.
330noob is offline
Old October 30th, 2010, 02:12 PM
Are you going back to stock or ....? If your building a street motor post what your doing because I may follow down your path!!!!
Thanks in advance!!
oldcutlass is online now
Old November 1st, 2010, 08:17 AM
330noob's Avatar
oh ya i guess that would help lol
i have a 65 f85 olds with stock 330 and wanted to keep it stock. what do you have?
330noob is offline
Old November 1st, 2010, 08:35 AM
67 Cutlass holiday Coupe -330 high compression - I was thinking on rebuilding beyond stock though!
Old November 1st, 2010, 09:20 AM
330noob's Avatar
oh really? on another thread a guy said that a lot of 330 and 350 parts are interchangeable, but don't quote me on this. i really want to know if that is true. i would really like to know if that is true
330noob is offline
Old November 3rd, 2010, 06:47 PM
330noob's Avatar
does anyone know if 330 and 350 parts are interchangable?
330noob is offline
Old November 3rd, 2010, 08:22 PM
Impin''s Avatar
This might help a bit. I'm in the process of contemplating what to do with my '65 330 and found this link.... https://classicoldsmobile.com/forums...ine-build.html
Impin' is offline
Old November 4th, 2010, 12:16 AM
Redog's Avatar
I have a 330 too, going o be building it up a bit.
Valves are different sizes starting in 73, but just about everything with the exception of the exception of the manifold will swap from a 64-90 SBO and 68-76 BBO
Redog is offline
Old November 4th, 2010, 12:35 PM
330noob's Avatar
so it is possible to use sb and bb parts on the 330 except for the intake? thats awsome. but if you change the heads to a sb from a 350 wouldn't you also be able to use the intake for it too?
330noob is offline
Old November 4th, 2010, 07:50 PM
2blu442's Avatar
The 330 and 350 are both small blocks. Everything that bolts onto the block will interchange. Even the crank shafts will interchange. Since the 330 all had forged cranks some people use the 330 crank in a 350, which came with cast iron cranks. If you have time you might go to the wiki site, use the following link: http://www.oldsmobilewiki.com/index....gory:Top_level This will give you a lot of information about the 330 and 350 engines, plus the big blocks if you want to compare the different options for your car.
John
2blu442 is offline
1965F85_scholten
July 13th, 2013 02:57 PM
442dreamer
August 23rd, 2011 07:28 AM
Gary's 2 442-S
August 14th, 2011 12:04 PM
442oldslawyer
April 29th, 2010 09:22 PM
jessejames
March 20th, 2009 08:01 PM
Quick Reply: need help on 330 rebuild!!
