no oil coming thru push rods
Old March 17th, 2009, 06:20 AM
olds4life's Avatar
hey olds nation. what would cause oil not to flow thru the push rods up to the rocker arms. the 2,3 and 4 rockers aren't getting oil up to them. i checked the push rods and the are not clogged up. could it be the lifters. could this cause it to make a tapping noise. thanks
olds4life is offline
Old March 17th, 2009, 09:18 AM
Yes and yes
joe_padavano is online now
Old March 21st, 2009, 04:45 PM
Warhead's Avatar
See lifter tick in Big Block section.
Did you blow compressed air through them?
Rarely does the lifter itself do this, it's usually particles (debris), or heat that gums up the works.
Or lost oil pressure (oil level/oil pump/drive).
Jim
Warhead is offline
65cutty
September 8th, 2010 02:22 AM
defiant1
March 6th, 2010 07:00 PM
Atdog
February 14th, 2009 06:51 AM
MY71CUTLASS
October 4th, 2007 12:21 PM
Pinner
May 31st, 2007 12:26 PM
Quick Reply: no oil coming thru push rods
