oil light comes on when the car stops
Old June 1st, 2010, 08:05 PM
rodrieguz's Avatar
when I apply my brakes the oil light comes on flickering on & off
also my generator light stays on but very dim, any ideas what could cause this?
rodrieguz is offline
Old June 1st, 2010, 08:09 PM
wjustinmartin's Avatar
low oil?
probably a short in the dash harness
wjustinmartin is offline
Old June 1st, 2010, 08:56 PM
Danny Wiseley's Avatar
Engine could be worn out, or just low on oil, or idling too slow.
This is usually caused by a bad diode trio, or external voltage regulator, depending on the year.
Danny Wiseley is offline
Old June 2nd, 2010, 02:52 AM
Yellowstatue's Avatar
Could be that your idle is a little too slow...
Yellowstatue is offline
Old June 2nd, 2010, 05:05 AM
rodrieguz's Avatar
This might be the problem as I did adjust the idle lower a few days ago. I will try it later, the check for faulty wiring.
Old June 2nd, 2010, 05:29 AM
Lady72nRob71's Avatar
You might consider getting a cheap mechanical oil pressure gauge to install in place of the switch, until you get the problem figured out. The oil light switch closes at about 6psi, so that is way too low to continue running the engine.
Hope it is one of the easy problems mentioned...
Lady72nRob71 is offline
dingusboy
February 24th, 2018 01:09 PM
59Olds98
December 25th, 2013 08:20 AM
Octania
October 24th, 2013 12:19 PM
erke88
September 27th, 2010 02:19 PM
Dkrone
May 1st, 2009 08:39 AM
Quick Reply: oil light comes on when the car stops
