oil pressure problem
Old August 1st, 2013, 01:57 PM
stormydns's Avatar
Alright everyone reciently bought a 81 cutlass with 403 and 350 trans I opted to replace it with a rebuilt 69 350 bored .30 over. All in and hooked up. When I prime it I can get oil to passenger side of the lifters drivers side stays dry so I pulled a few rods on driver side they are clean and clear tried putting dissy in and turn engine over no oil pressure with dissy in. Curious if because I took the hei dissy out of the 403 if thats the coulprit and I need to get a new one because if I can stick a drill and prime and get oil to passenger side obviously my pump works ....idk im just stumped any help please
stormydns is offline
Old August 1st, 2013, 02:52 PM
It takes a while, drill needs to turn CCW.
oldcutlass is online now
Old August 1st, 2013, 04:14 PM
stormydns's Avatar
I actually had engine running for 25 minutes and noticed no pressure on my gaugr then went exploring have had drill going for 5 min in 30 sec intervals with dissy in I get nothin to lifters with shaft in after about 10 sec pass starts pumping oil through rods one at a time until all have it coming out but never a drop through driver side. Rods are all clear no restriction hsve even tried bumping engine while priming to no avail this is my first sbo install and im stumped
Old August 1st, 2013, 05:22 PM
Octania's Avatar
has the engine been apart?
Sounds like the plug at the aft end of the LH passage was not installed. A glance down in the distributor hole while running the drill should show that as a huge gusher of oil spewing out of the aft end of that passage onto the oil pump drive shaft &c.
Octania is offline
Old August 1st, 2013, 06:44 PM
stormydns's Avatar
Theres oil on pump etc but shouldnt there be oil when priming
Old August 18th, 2013, 09:58 AM
Octania's Avatar
yes
there should be a tiny spit of oil onto the oil pump drive shaft while you spin it w/ your drill.
Not a finger sized gusher, which would indicate that the plug is missing. No spit of oil would indicate the plug has no hole.
Octania is offline
Old February 8th, 2019, 01:31 PM
ves007's Avatar
Thanks to all. I also had a pressure issue.I still have a 403 Olds engine that I purchased. I had it bored, honed, line bored and hot tanked. The machinist told me about the two oil galley plugs in front but never told me about the oil galley plug that sits inside the block behind a press in plug. I was on this forum for about three hours before I read the post. I did leave out the plug. I had to drill it out, just enough to get the distributor gear wet with oil. You guys saved me a lot of work trying to find it.
ves007 is offline
Old February 8th, 2019, 04:06 PM
72 Olds CS
RetroRanger's Avatar
good to know very common to miss that plug or not have a hole in it
RetroRanger is offline
ponder48
May 31st, 2019 07:35 PM
The Swede
January 8th, 2015 10:49 AM
chrisntam
July 31st, 2013 07:46 PM
jaygtx440
September 21st, 2012 09:07 PM
JRios
September 29th, 2010 08:39 PM
Quick Reply: oil pressure problem
