Oil pressure sending unit too big
Old August 18th, 2011, 06:36 PM
Where were you in '72?
boondocker's Avatar
Just got my new AutoMeter gauges and my oil 100 pressure sending unit is huge, big enough that it won't fit behind the water pump location. Has anyone encountered this and what is the remedy...different sender?
boondocker is offline
Old August 18th, 2011, 06:41 PM
Originally Posted by boondocker
... what is the remedy...different sender?
Longer piece of pipe, or a 45° angle fitting.
MDchanic is offline
Old August 18th, 2011, 07:14 PM
Lady72nRob71's Avatar
The factory used a 45* extension piece...
Lady72nRob71 is offline
Old August 18th, 2011, 07:17 PM
Funkwagon455's Avatar
I'm pretty sure these are still available though Fusick/Year One/OPG ect.
Funkwagon455 is offline
ozoneblue's Avatar
You are about to become a certified plumber . 1 atta boy
ozoneblue is offline
Old August 18th, 2011, 07:19 PM
I'm pretty sure they're cheaper at the corner hardware store.
MDchanic is offline
Old August 18th, 2011, 07:44 PM
I looked for one there but never found one. I just coughed up the 20 for one at the parts place, and it even fit without modification!
Who said you had to have brains to be a plumber.......
Old August 18th, 2011, 08:50 PM
stevengerard's Avatar
yep they make reproductions for it but you can also use the NPT fittings from the hardware store - either will work
stevengerard is offline
Old August 19th, 2011, 11:57 AM
boondocker's Avatar
Little funky looking, but should work.
Old August 19th, 2011, 12:19 PM
Nothin' funky there - looks great!
Just what I was talking about.
If you really wanted to go nuts, you could always "customize" those fittings with a grinder.
MDchanic is offline
Old August 19th, 2011, 12:21 PM
I've never seen galvanized fittings in such a small size..........
BTW, where is your bypass hose?
Old August 19th, 2011, 12:32 PM
boondocker's Avatar
Thanks for all the help guys...Rob, my engines still under construction, hope to have it in the chassis this weekend.
Old August 21st, 2011, 10:50 PM
64Rocket's Avatar
I would have used brass like the factory.
Gene
64Rocket is offline
Old August 22nd, 2011, 04:42 AM
Chesrown 67 OAI's Avatar
Gene
X 2 !! Got to auto parts store and get those pipe fittings in BRASS! Makes a much better looking installation! Any NAPA store will have them!!
Chesrown 67 OAI is offline
Old August 22nd, 2011, 05:02 AM
Never knew Napa had those - great tip!
Old August 22nd, 2011, 10:03 AM
Redog's Avatar
Home Depot and about $2.
I "T"ed mine because I kept the factory oil light. I used a 1/8 brass fitting from a fuel gauge pod that I had laying around. A double ended (like a striaght pipe with threads) 1/8 male fitting and a 1/8 T fitting.
USE TEFLON TAPE!!!
Redog is offline
TheRuss
January 22nd, 2018 11:42 PM
68RocketAction
December 18th, 2014 11:19 AM
Chris J
March 31st, 2013 07:09 PM
mmurphy77
March 13th, 2011 08:08 PM
boese1978
January 22nd, 2008 11:56 AM
Quick Reply: Oil pressure sending unit too big
