Oil pressure sensor too fat
Old April 28th, 2014, 02:08 PM
1969 cutlass convertible
Tim305's Avatar
I bought a set of electric (not mechanical) Gauges for my 69 cutlass 350. Problem is the oil pressure sensor is too large in diameter to fit. The location of the sensor hole is located too close to the block. I was wondering if I got a 3 inch brass extension to raise it up past the block if that would work? Or would it not read accurate?
Tim305 is offline
Old April 28th, 2014, 02:19 PM
oldsmobiledave's Avatar
Fyi
You can put an extension on it to raise it or a elbow that will raise it and then mount it flat. I have done both and both work fine.
oldsmobiledave is offline
Old April 29th, 2014, 08:28 AM
Which is exactly what the factory did on cars with gauges. The factory part looks like this and is available repro, but hardware store 1/8" NPT fittings work just fine if you don't care about 100% correct appearance.
joe_padavano is online now
Old April 29th, 2014, 10:39 AM
Chevy budget Olds powered
coppercutlass's Avatar
Stupid question but do they sell these units at the local carquest ? If so do any members have a part # for it for a sweep style gauge.
coppercutlass is offline
Old April 29th, 2014, 11:16 AM
Nop
2-stroke 1-cylinder guy
Nop's Avatar
I ordered some fittings and adaptors, and ended up with something like this:
About 2" long, 2 female 1/8"-27 NPTF ends, a side 1/8"-27 NPTF hole, and a male to male 1/8"-27 NPTF piece for screwing one end into the block, bought it on eBay.
Your local Harley dealer might be a good source for that kind of 45°/straight brass, steel and copper NPT stuff.
Nop is offline
Old April 29th, 2014, 03:36 PM
Tim305's Avatar
Tim305 is offline
dacutty
March 28th, 2014 09:01 AM
nanardos
September 1st, 2013 09:41 AM
Olds64
October 13th, 2010 08:04 PM
orange442
October 8th, 2010 08:37 AM
ej69
September 14th, 2009 07:20 AM
Quick Reply: Oil pressure sensor too fat
