Olds 215-Why is this linkage spring here? Mine's missing
63 Olds 215 4bbl.Does anyone out there( maybe Joe P.),know what this
linkage spring does? Mine is missing.It appears to somehow control the
transmission downshift function,but how? I've spent about an hour opening
and closing the linkage on my 4bbl trying to figure what this spring does.
The picture is the linkage on a 62 Cutlass 215 4bbl. owned by my son.
This spring is enormous,and must control transmission function in some way.
It it a tension or a compression spring? Can anyone tell me why this is here?
It's part of the throttle valve linkage. The RotoHydramatic 5 doesn't use a kickdown, it uses a throttle valve (like a 200-4R or 700R4) to modulate line pressure in the trans based on throttle position. The TV rod also acts as the kickdown link. The RH5 has a "feature" that you could fully open the throttle without activating the kickdown if you wanted to on the freeway, then by pressing slightly further on the throttle this bellcrank would activate the kickdown.
Of course, I eliminated this when I went to the E-brock carb on mine and had to fabricate my own throttle and TV linkages.
Joe, Thanks for the reply. Does this spring hold back the downshift
process until the pedal is completely depressed? As my car is now, it will
downshift to 2nd at speeds under 35-40 mph. At speeds above it I have to
push the pedal to the floor and even then I can only feel the 4bbl open up.
Downshift linkage must not be properly adjusted or I would get passing
gear when I push the pedal to the metal. Will be checking that out.
After some searching at swap meets and parts stores I found a spring
that closely matches the one in the picture. Took about an hour to install
and readjust the linkage to the spring. My opinion is that this spring holds
the transmission linkage up tightly in a firm position. Without it my trans
shift points would vary constantly with every stop and start. This linkage
has a slot in it which is not visible in the picture, but allows movement for
passing gear when the pedal is pushed to the floor.
The TV rod is attached to this slotted portion of the linkage, and will
move into infinitely variable positions without this spring attached to it.
The result is with every stop and start,you end up with a different TV
adjustment. This changes the 1-2 shift every time you start out from a
stop. I would like to have back the hour or two of my life I've spent
adjusting and readjusting the TV rod to get the right 1-2 shift point.
The answer to the original question is....the spring holds the linkage
together to keep shift points consistant.
71este
June 16th, 2014 09:08 PM
Longhorncutlass
March 2nd, 2009 01:53 PM
