olds 307 chevy 350 swap
Old January 21st, 2008, 03:27 PM
wdm3000's Avatar
Angry olds 307 chevy 350 swap
gotta problem friend gave me chevy 350 when he totaled his camaro cause i needed a motor for my 84 custom cruiser well after much work and toil i found that the mounts and tranny do not match up i know the gm mounts or that era were bolt in so new engine mounts will be no problem my question comes to will the 200 r4 hold up to a 450hp motor or will i have to get a new tranny and torque converter if so how hard are the tranny swaps
wdm3000 is offline
Old January 21st, 2008, 04:32 PM
EVERYTHING is different - motor mounts, trans (possibly, unless you have a unisex 200-4R), accessory brackets, manifolds, etc. The A/C and starter are on opposite sides and require rewiring/replumbing. The easier solution is to sell the Chevy and buy an Olds 350 or 403.
joe_padavano is offline
Seasoned beater pilot.
J-(Chicago)'s Avatar
That trans will work, but you will have to get it built up. Do a search on here there are several posts about it and the builder I think his name is Brian Hofer. Also you will need a trans bolt converter plate because B.O.P transmissions will not bolt right up
J-(Chicago) is offline
Old January 21st, 2008, 09:38 PM
Originally Posted by J-(Chicago)
...Also you will need a trans bolt converter plate because B.O.P transmissions will not bolt right up
Actually, I think all 200-4R transmissions have the dual bolt pattern case.
Old January 22nd, 2008, 01:58 AM
BONUS!
Old January 22nd, 2008, 12:04 PM
Junior Member
88 coupe's Avatar
........ found that the mounts and tranny do not match up ........
http://gbodyforum.com/viewtopic.php?t=2901
Norm
88 coupe is offline
Old January 22nd, 2008, 12:12 PM
Junior Member
88 coupe's Avatar
........ will the 200 r4 hold up to a 450hp ........
Your friend gave you a 450 HP Chev engine?
Norm
88 coupe is offline
glendalegearhead
July 5th, 2015 11:25 PM
falconsfan
May 14th, 2015 05:47 AM
Jolds86
December 16th, 2014 07:49 AM
jonlewis09
November 25th, 2013 12:58 PM
deltaroads
May 14th, 2011 08:54 AM
Quick Reply: olds 307 chevy 350 swap
