Olds Gold Engine paint. (72 350 Rocket)
Old November 18th, 2012, 10:39 PM
AirborneRME's Avatar
I've got a 72 Cutlass S that I recently bought for my dad. I'm looking for some reproduction engine enamel in that Olds Gold. anyone have any leads or suggestions on what brand is best to go with?
Any pics/examples would be great. Thanks!
- R.J.
AirborneRME is offline
Old November 19th, 2012, 03:11 AM
If you use your Search function, you will find threads on this subject here, here, here, here, here, here, and here, for starters.
MDchanic is offline
Old November 19th, 2012, 03:37 AM
Del70's Avatar
Maybe someday..the original paint Mfg. and color codes (mix) for the 68-72 Olds Eng gold and 455 blue will be discovered in some factory paperwork..
Del70 is offline
Old November 19th, 2012, 04:05 AM
The problem with that is that all of the raw ingredients (pigments, binders, base, etc.) have changed since then, and the originals are no longer available.
An experienced paint man can often figue out general equivalences, but exact translations are difficult to impossible.
Also, with constantly tightening environmental regulations, in a wide variety of jurisdictions, the raw ingredients of today may not be those of tomorrow.
MDchanic is offline
Old November 19th, 2012, 05:18 AM
Roger Kent's Avatar
Olds Gold Engine Paint
Hi, an American company called POR supply a one pint tin of Olds Gold engine paint and is good for temps up to 300f. If you go to http://www.por15.com/Engine-Enamel/products/7/ you will see they do either the paint or a complete kit option.
I've used it myself and can say it has lasted well on my 1975 Delta 88 Royale under English weather conditions. If you want to see the Olds she is on www.kentuckycars.co.uk
Roger Kent
Roger Kent is offline
Old November 19th, 2012, 06:39 PM
Thanks, may try going to napa and seeing if they can mix some!
-R.J.
code26
February 9th, 2015 11:09 AM
OldsW29
May 21st, 2014 03:25 PM
Grant1424
April 19th, 2012 07:33 PM
cutlassKing
November 29th, 2010 03:05 PM
RAMBOW
March 14th, 2010 07:44 AM
Quick Reply: Olds Gold Engine paint. (72 350 Rocket)
