Piston recommendation for higher compression
Old April 20th, 2011, 12:16 PM
Where were you in '72?
boondocker's Avatar
I'm in the process of rebuilding my '72 350, will be reboring 30 over and wanted to go with a smaller dish piston to boost my compression high enough to run regular octane while increasing performance. Any spec/manuf suggestions?
...also have a XE262H, heads are done (3 angle etc...)
boondocker is offline
Old April 20th, 2011, 01:13 PM
boondocker's Avatar
I found a cast iron piston from Mondello 11.9cc with 7a heads should be 9:14:1...is this regular octane friendly?
http://www.mondellotwister.com/PisPinRingBrng.htm
Old April 20th, 2011, 02:01 PM
cutlassefi's Avatar
Cast iron?
9.14 is pump gas friendly.
cutlassefi is online now
Old April 20th, 2011, 02:26 PM
boondocker's Avatar
Thanks, 87 octane?
"Cast Iron" is what Mondello refers too...is this the rings?
Old April 20th, 2011, 05:41 PM
cutlassefi's Avatar
Thanks, 87 octane?
Should be Cast Aluminum pistons with Cast iron rings.
Imo you can do better for not a lot more money
http://webcache.googleusercontent.co...istons&ct=clnk
Use a moly ring if possible, not that much more.
Jmo.
Btw 89 octane, maybe, depending on the cam and gear.
Old April 22nd, 2011, 08:57 AM
boondocker's Avatar
I'm looking at a TRW piston set (NOS) with the following specs;
TRW L 2389F .040 OVERSIZE FORGED PISTONS AND ONE SET OF TRW T 8190X OVERSIZE CAST PISTON RINGS
2.932" X .235" DEEP CUP,1.610" COMPRESSION DISTANCE AND A .980" DIAMETER PIN.RINGLANDS ARE FOR 5/64",5/64",3/16" RINGS
Are these slightly higher compression than stock (stock 2.920/0.215 dish and compression distance is 1.595)?
.040 is mentioned is this non standard (.030)?
Thanks for all the advice
Old April 22nd, 2011, 10:11 AM
2.932" x 0.235" looks to be 26cc, which is quite deep.
MDchanic is offline
Old April 22nd, 2011, 11:49 AM
boondocker's Avatar
I'm not sure if the larger compression distance (between wrist center and piston top) would bring it closer to the head giving more compression. It looks to be a pretty low compression piston in any case...
Old April 22nd, 2011, 12:47 PM
If you calculate the volume displaced by the 41.49 square cm of the "ring" around the dish and the 0.015" higher that the crown should sit with the different height, you get a 1.58cc decrease in combustion chamber volume, which seems insignificant in comparison to the 12cc increase in combustion chamber volume due to the increase in dish volume from 14cc to 22cc.
Last edited by MDchanic; April 22nd, 2011 at 01:41 PM. Reason: Recalculated for 0.040" additional piston diameter.
MDchanic is offline
72cuttys
March 30th, 2014 07:43 PM
skubydobdo
February 3rd, 2014 03:25 PM
jfb
February 15th, 2013 10:00 AM
dirtydynamic
December 27th, 2011 08:34 AM
69Rman
March 27th, 2010 10:22 AM
Quick Reply: Piston recommendation for higher compression
