Please help OLDS 330
I got this project a 1967 oldsmobile cutlass 4-door hardtop with an olds 330, it is a project. I have already done some things to it, installed HEI, new spark plugs, new water pump, new fuel pump, cleaned the gas tank, new spark plug cables, rebuilt the 4 barrel Quadrajet carb, and new radiator, I did not like how it drove as it started very slow in gear, and very hard to pick up speed
I thought it was the ST300 transmission failing, so I replaced it and put a 3-speed TH350 transmission in it, a very straightforward swap, after the transmission swap it got a little bit better but still, it has trouble picking up acceleration, one example if I press the pedal half throttle it will hardly move, then I put it in neutral without letting go off the throttle and the engines revs high, engine works very good while is not under load, I checked for vacuum leaks and did not seem to find any, it did the same thing with the ST300 transmission I am at lost here any help. PLEASE!!???
The car should at least creep forward when you take your foot off the brake with the engine idling. Speaking of, have you done any work to the brakes yet? One of the drums/calipers could be sticking.
I put new drums and brakes including wheel cylinders all around, let me check the adjustment on the wheels. , one key thing I disconnected the HEI vacuum advance, and seems to run a bit better not excellent but better, any advice on why that happened?
Just a thought - do you have the TH350’s kickdown cable and vacuum modulator connected properly? The kickdown cable needs to be adjusted properly as well. If it’s not, the transmission could stay in 3rd gear when you floor the pedal, and the acceleration would be dismal (I had that happen before).
Great advise I will try that Tommorrow too, thank you again.
Update fixed
Just an update I advance the timing just a little bit unknown to what degrees, as the engine is missing the timing marks, however car now accelarates as it should love my four door oldsmobile cutlass hardtop. Thank you everyone for all the advise provided.
Alex Cat
March 4th, 2022 09:37 AM
57JoeFoMoPar
October 1st, 2021 03:47 AM
