Ram Rod 350 question
Old September 24th, 2012, 06:30 PM
'S'tuff1979's Avatar
Question Ram Rod 350 question
Hi ya'llllllll
I saw a pic pn craigslist of a ram rod engine and it had 395558 2 on it
well the engine in my car does too. It has #6 heads though.
questions are
Is this a ram rod hermorphidite?
Is there anyhting special about the ram rod block or pistons or anything?
if it is a ram rod should i try to aquire #5 heads for it?
'S'tuff1979 is offline
Old September 24th, 2012, 06:31 PM
also
Originally Posted by 'S'tuff1979
Hi ya'llllllll
questions are
i always thought the pulley and balancer were gigantic on this engine haha....
Old September 24th, 2012, 06:39 PM
L69
L69's Avatar
same block and the heads whether 5 or 6 will have the big valves for any w31. Also flat top pistons and yes the harmonic is different as is the pulley, extends further. I am sure a w31 guy will chime in.
L69 is offline
Old September 25th, 2012, 08:25 AM
Hi ya'llllllll
questions are
1) If you have to ask, yours is NOT a Ram Rod.
2) All Olds 350s, from the low compression 2bbl to the Ram Rod/W-31 motors used the same block and head castings in a given year.
3) The differences are all internal - flattop pistons for higher compression, bigger valves, and a more radical cam.
joe_padavano is offline
71HolidayCutlass
November 9th, 2018 06:14 PM
jaydc68
September 16th, 2013 08:21 PM
'S'tuff1979
September 24th, 2012 06:24 PM
442ric
May 30th, 2011 07:27 PM
72 Supreme
July 12th, 2008 06:28 PM
Quick Reply: Ram Rod 350 question
