Roller rockers with non roller lifters
Old August 13th, 2008, 02:43 PM
Redog's Avatar
I've been looking around and getting ideas on my rebuild and such and I'm looking at roller tip rockers.
Can I use these with flat tappet lifters? Can I use full roller rockers with these lifters?
I want to stick with the edelbrock 7112 cam to match my intake and that is a flat tappet cam.
Redog is offline
Old August 13th, 2008, 04:01 PM
Roller rockers and roller lifters are unrelated. You can use either separately or both together. Roller lifters refer to a roller follower on the camshaft end of the lifter. Roller rockers refer to a roller on the tip of the rocker that pushes on the valve. Some roller rockers also have roller bearings on the rocker pivot itself.
joe_padavano is offline
Old August 13th, 2008, 04:31 PM
Redog's Avatar
OK I know they are 2 totally sepreate things, but my mech was talking about roller cams, lifter, and rockers.
$867 for a roller cam and lifters, $1067 adds the timing chain
Now paying $209 for the cam and lifters isn't too bad
Redog is offline
Old August 13th, 2008, 04:32 PM
Redog's Avatar
I know they are 2 different things, I just was wondering if I could mix and match
$1067 for a cam set is too much IMO
Redog is offline
Old August 13th, 2008, 05:19 PM
captjim's Avatar
Sure, you can have roller lifters/cam and regular stamped rockers. Don't know why you would, though. Many guys, myself included, have flat tappet cams and roller rockers. Roller cams do have advantages, but their major disadvantage is the initial cost.
captjim is offline
Old August 13th, 2008, 05:26 PM
Past Administrator
Oldsguy's Avatar
However, if you do use a "roller" cam, that implies that you will be using the roller rockers as the ramps on the cam lobes are different than those on a flat tappet cam that would have similar total lift.
Oldsguy is offline
Old August 13th, 2008, 05:34 PM
captjim's Avatar
I should have added that, thanks oldsguy. I always buy lifters in a matched set with the cam, never swap lifters from another cam, etc.
captjim is offline
Old August 13th, 2008, 05:46 PM
Redog's Avatar
No, my plan is to run a flat cam and roller rockers, I'll probably go full roller
Redog is offline
Old August 13th, 2008, 05:47 PM
Redog's Avatar
No I won't.
I'm going to buy the Edelbrock 7112 cam to match my 7111 intake
Redog is offline
Old August 14th, 2008, 05:55 AM
Junior Member
88 coupe's Avatar
Originally Posted by Oldsguy
However, if you do use a "roller" cam, that implies that you will be using the roller rockers ........
Since, I don't know much about "implications".
            Whether the rocker, has rollers in (or on) it, is a personal choice, as it is not required.
              Norm
              88 coupe is offline
              Old August 14th, 2008, 11:53 AM
              Junior Member
              88 coupe's Avatar
              Talking
              ........ never swap lifters from another cam, etc.
              This only applies to used lifters. They must be reinstalled on the same lobes, of the same cam. With new lifters, the sequence doesn't matter.
              New cams, lifters, and springs, do not care what name they are marketed under. As long as the new lifters and/or springs are are correct for the application, the manufacturer is not relevant.
              Norm
              88 coupe is offline
              Old August 14th, 2008, 12:48 PM
              captjim's Avatar
              Norm
              That is what I meant, sorry for not being clear enough on the matter. But, just my opinion, stay away from el-cheapo lifters, not worth the few $ you save.
              captjim is offline
              Old August 14th, 2008, 06:56 PM
              Junior Member
              88 coupe's Avatar
              That is what I meant ........
              Welcome to the site.
              Norm
              88 coupe is offline
              bluecab
              September 14th, 2021 07:52 AM
              RROLDSX
              March 8th, 2013 05:50 PM
              Pryora
              August 6th, 2012 11:30 AM
              oldzy
              May 1st, 2012 11:37 PM
              oldzy
              August 6th, 2011 05:28 AM
              Quick Reply: Roller rockers with non roller lifters
