rough idle
Old June 28th, 2008, 09:55 PM
projectheaven's Avatar
rough idle
I'm having a problem with my 72 cutlass and I hope my olds family can help.
I installed a new gas tank last weekend because the previous owner popped the locking gas cap when he couldn't find the key.He screwed up the filler neck.
The problem is since the install the car hesitates and idles lower than usual.It starts up fine but just idles low around 3-4 hundred rpm.I have a see through fuel filter and theres pleanty of gas going through it.What do you think???
Last edited by projectheaven; June 28th, 2008 at 09:59 PM. Reason: left out problems
projectheaven is offline
Old June 29th, 2008, 08:32 PM
If you installed a new tank maybe you dislodged some stuff in the sender unit. It could have come loose in your fuel line and gotten lodged in the carburetor. Maybe cleaning the carburetor would help.
Olds64 is online now
Old July 8th, 2008, 12:16 AM
Problem fixed.It was the filter on my sending unit.It was sliced open so junk was getting to my engine.I replaced it and I'm good again and burning rubber up and down the block.
1971olds350
April 29th, 2009 08:59 PM
68ragtop
August 24th, 2008 09:44 AM
skubydobdo
August 18th, 2008 03:32 PM
novice57
June 3rd, 2008 04:35 AM
UCF72Cutlass
May 31st, 2008 07:09 PM
Quick Reply: rough idle
