running lean
Old June 20th, 2008, 10:31 PM
projectheaven's Avatar
running lean
Hello all,
How do you know if your car is running lean?
Also,What can be done to correct it?
projectheaven is offline
Old June 21st, 2008, 10:21 AM
Past Administrator
Oldsguy's Avatar
Easiest way is to read the plugs. I think there was a thread on this site about spark plugs and someone posted a cool link to a lot of pictures of spark plugs and what they mean. Basically, if you find the plug tips to be very white and perhaps even burnt away in some places then you are running too lean. But don't get that confused with the idle mixture setting which ONLY affects rich/lean condition at idle. The jets in the carb determine if the carb is running lean or not. If you think your carb is stock and unmolested I don't think you would have a lean problem.
Oldsguy is offline
jpc647
June 8th, 2013 06:39 PM
Supreme78
August 21st, 2012 03:56 PM
scooter123
April 13th, 2012 08:33 AM
fasteddi
July 15th, 2011 06:36 PM
musicars
September 1st, 2007 05:46 AM
Quick Reply: running lean
