Spun Bearings
Old June 10th, 2013, 04:55 PM
Ben
i9730lds's Avatar
Spun Bearings
Hello,
I have had four stock Oldsmobile engines spin bearings. One 403, and three 307's. Everytime this happens it is the 7/8 rod journal that takes the worst damage. Was I reving the engine too much? Is this a coiencedence, or is this typical for Olds engines? None of the engines had more than 100k miles.
Also, is it possible to swap in a 350 crank into a 403, and if so what is involved to make everything work properly/
i9730lds is offline
Old June 10th, 2013, 05:07 PM
... Which begs the question: How high were you revving them?
Welcome to Classic Olds.
MDchanic is offline
Old June 10th, 2013, 05:45 PM
Oldsmaniac's Avatar
Longevity depends on maintenance and regular service as well as what has been asked from the engine. It also depends on how well or tolerances when it was first put together. An engine nearing 100 thousand miles in my book is tired. I do not believe the bearings (numbers) that you noted as spinning are a common problem with Olds engines in general.
Oldsmaniac is offline
Old June 10th, 2013, 05:56 PM
Ben
i9730lds's Avatar
If it is just tired engines, then i'll call it a day and move on. any thoughts on swapping the 350 nodular crank in a 403?
i9730lds is offline
Old June 10th, 2013, 06:08 PM
Octania's Avatar
Yes, i think this-
If you are going to do that much work, start with a 330 forged crank.
Same re-balance, one more part [flexplate].
FAR nicer piece of metal.
Octania is offline
Old June 10th, 2013, 06:51 PM
Ben
i9730lds's Avatar
The front balancer on the 350n crank is noticibly thicker (and heavier). do i need to rebalance the whole assembly including pistons, rods, crank, balancer, flexplate? Or do I just use the 350 crank assembly and 403 rods/pistons without complete disassembly and machining. I wasn't looking to drop a grand for a crank swap.
i9730lds is offline
sicky olds
February 29th, 2012 01:36 PM
oldzy
Drivetrain/Differentials
September 14th, 2010 05:40 AM
olds455
July 22nd, 2010 06:16 AM
Topless72
April 9th, 2008 11:47 AM
OLD SKL 69
January 24th, 2008 08:36 AM
Quick Reply: Spun Bearings
