thermostat housing
Old May 3rd, 2023, 04:57 PM
GKranig1's Avatar
thermostat housing
will a thermostat housing from a 1966 330 work on a 1972 350,also i want to put a fuel filter on,should it go between fuel pump and tank or between pump and carb.thanks for replies.
GKranig1 is offline
Old May 3rd, 2023, 06:26 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
It will bolt on, there variations, the curved hose is available for the short outlet style. Install the fuel filter before the pump.
olds 307 and 403 is offline
Old May 4th, 2023, 08:46 AM
Old(s)GuysRule
67OAI's Avatar
There is a filter of sorts on the fuel pick up inside the tank. Some folks put the "add on" fuel filter before the fuel pump, others put it between the pump and the carb. The safer place would be before the pump but plenty of us have had success placing it in a safe area between the pump and the carb. Stay away from the glass filters and also the plastic ones. I would use only the metal filter for safety reasons.
67OAI is offline
Old May 4th, 2023, 09:01 AM
35tac's Avatar
FYI same as above on my 66 Cutlass 330. My filter is after the pump and only use the metal inline filter. No problem so far and runs fine.
Wayne
35tac is offline
rktrde303
January 22nd, 2023 01:05 PM
rpinnt
February 16th, 2016 06:41 PM
wcourt3010
April 13th, 2015 12:10 PM
DENT
December 31st, 2012 12:53 AM
oldspower_68
March 23rd, 2012 02:18 PM
Quick Reply: thermostat housing
