torrington bearing
torrington bearing
I was going to install a torrington bearing on my 403 to keep the new hydraulic roller cam from walking. My engine is already together so id rather not take it apart to machine the block for the bearing or do you not have to take the engine apart to do this? I dont know how the machine shops go about this. My other question is if i can just remove the camshaft and machine a step in the end of the cam for the bearing to fit in?
No, you have to remember a roller will do so even less. The lobes aren't ground to make the cam push rearward like on a flat tappet. Plus you should have plenty of oil coming out if the front cam bearing to lube the area.
Normally I drill a .030 hole thru the oil galley in the face of the thrust surface for the cam if it's a flat tappet. That'll help but it's really not necessary, especially on a roller.
ok i took the spacer off the cam and put the cam back in to see how the rollers were lined up with the lobe centerline. Its a little better. Does it have to be exactly in the middle? Id say judging by looking that the the lifter is about 1/16 of an inch from being center.
Flye
Drivetrain/Differentials
July 30th, 2009 10:24 AM
J'ville
September 4th, 2007 09:50 AM
