What type of carb to get
Old June 15th, 2012, 09:32 AM
455man's Avatar
I'm searching craigslist for a rebuilt or fairly new quadrajet to place on a Performer RPM. I'm assuming I'd need something with an electric choke or a carb that I can convert to electric choke. What carb could I use for this application? I was told a 4MV could not be converted to electric choke.
455man is offline
Old June 15th, 2012, 09:43 AM
Any carb with the integral choke (big round black plastic thing on the side, '70 and later) can be used with an electric choke.
Divorced choke carbs ('69 and earlier) cannot.
Of course, there's always a manual choke...
MDchanic is offline
Old June 15th, 2012, 09:52 AM
455man's Avatar
I'd rather use an electric choke so I dont have to mess with it.
So the climate controlled (heat) or automatic choke mounted on the carb could be converted to an electric choke. Like this one?
455man is offline
Old June 15th, 2012, 11:04 AM
Rickman48's Avatar
Yes - the 80's CCC carbs have electric chokes that go right on.
Check Hemmings for a rebuilder close to you - he might have a direct replacement, or want to do your core.
IMO - the biggest problem with Q-jets is the throttle shafts - leak vacuum when worn.
Bushings fix that, and once set-up correctly, need no maintainence.
Rickman48 is offline
Old June 15th, 2012, 11:37 AM
455man's Avatar
Sweet thanks guys.
455man is offline
Old June 15th, 2012, 06:33 PM
Just the facts...
BILL DEMMER's Avatar
i recommend a 704-series carb. as opposed to a 1705-series carb. primary metering rods with the correct taper, and power piston springs are much harder to come by for the 1705-series.
bill
BILL DEMMER is offline
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
blue4092
May 5th, 2012 11:58 PM
Allan R
July 2nd, 2011 10:01 PM
RAMBOW
November 29th, 2009 02:30 AM
OldsVentura
April 10th, 2009 01:43 PM
Quick Reply: What type of carb to get
