What's that sound?
Old May 30th, 2016, 09:32 PM
" Hoo yah "
815Cutlass1972's Avatar
What's that sound?
I recently got my 69 F85 running. I hear a noise coming from the engine compartment, maybe the passenger side, hard to tell exactly. I didn't notice the noise until I got the Edlebrock 600 to idle a bit better. Is anyone familiar with the noise in this video? It's more noticeable once I walked to the front if the car. Exhaust leak? Thoughts?
815Cutlass1972 is offline
Old May 31st, 2016, 07:25 AM
Maintained
scottv442's Avatar
if your referring to the ticking noise, it sounds like a bad lifter. The "whirring" noise is just the belts and possibly the tranny pump.
needs more investigation to determine if its exhaust or lifter.
scottv442 is offline
Old May 31st, 2016, 07:33 AM
Old School Olds
tru-blue 442's Avatar
Agree with Scotty. I'd be willing to bet he has a Jetaway on it's last leg.
tru-blue 442 is online now
Old May 31st, 2016, 08:02 AM
Alternator whirring is not out of the question, given the acoustic limitations of the average cell phone video.
MDchanic is online now
Old May 31st, 2016, 08:07 AM
" Hoo yah "
It's the "whirring noise", that i have not heard before, but I think your on track about the ticking sound. Its the original 350 to the car and it has sat for the last 3 years. Just had it shipped from California a few weeks ago. Let me tell you there were some "Godzilla" sized spiders hidden all over, and they are still popping out of places. I'll check the belts, but I thought it may be tranny related. The noise pretty much stops when the car is in reverse or drive.
Old May 31st, 2016, 08:10 AM
" Hoo yah "
Eric,
The noise was alot more noticeable when I stood next to the alternator.
Old May 31st, 2016, 08:12 AM
As the others said, belts, alternator, transmission, and I'll add power steering. Ticking is as stated valve train.
oldcutlass is offline
Old June 1st, 2016, 04:13 PM
Chevy budget Olds powered
coppercutlass's Avatar
You can pull the belt off the alt. And fire it up and see what happens.
coppercutlass is offline
Old June 1st, 2016, 05:04 PM
Olds Fever
CRUZN 66's Avatar
Possibly alternator bearing...
Purchase one of these, if you don't already have one... I have been able to pin point many different noises use this tool...
http://www.summitracing.com/parts/li...FQckhgodgmsGdg
CRUZN 66 is offline
Old June 1st, 2016, 07:38 PM
" Hoo yah "
I will check and see if Harbor Frieght has one. I'm cheap with tools, because the kids are always losing my stuff. It really sounds like the whirring noise is coming from the alternator.
Ulises.... I think Ill give it a try after i figure out this ticking noise.
I pulled the passenger side valve cover and the ticking sound seems to be coming from below the last two rockers toward the fire wall.
I wiggled on one rocker and got just a hair of play. I pulled on the rocker forward of the other and it would not wiggle at all. I inspected the push rods and they appeared straight. I changed the rockers arm with some extras. Thinking of pulling the intake and checking lifters. I'm hoping I can keep it for awhile without rebuilding it. I'm not ready to do that just yet. Got to sale parts and build up a F85 engine fund.
Kino
Old June 1st, 2016, 07:55 PM
If it sat for a long time it might be a sticky lifter or not pumping up possibly. Run some marvel mystery oil through it. Throw in a quart and let it run for a while if you can drive it even better. And if you need new lifters i have a set of howards lifters new in the box i can let go cheap or trade.
Old June 1st, 2016, 08:18 PM
" Hoo yah "
Good idea. I've read about the marvel mystery oil, and now is the opportunity to give it a try, especially since the car has sat for about three years. I'll wait until my valve cover gaskets arrive to replace the passenger side VC, since it tore apart when i pulled the p/s valve cover. I'd be interested in the lifters as I may need them later anyway.
VinnyC
August 13th, 2013 06:54 AM
cutlass66
Drivetrain/Differentials
February 15th, 2009 04:51 PM
jackmanola
July 6th, 2008 01:05 PM
daverbmxer
April 8th, 2007 09:28 PM
Cuttyon22s
November 20th, 2006 06:07 PM
Quick Reply: What's that sound?
