wood spacers vs. aluminum spacers
Old May 26th, 2016, 06:54 AM
86GutlessCutlass's Avatar
i have a edelbrock 1405 carb on my car and when i drive it it does good but if i shut it off say for maybe 10 mins and go back to start it up, it floods out and is hard to start due to heat of engine. and ive been told if i get a spacer that it would help this issue i just dont know if i should get a wood spacer or an aluminum spacer.
86GutlessCutlass is offline
Old May 26th, 2016, 06:57 AM
A phenolic spacer is better because it will not transfer heat. An aluminum spacer will.
oldcutlass is online now
Old May 26th, 2016, 07:00 AM
wr1970's Avatar
Why not ask Jesse. Sorry i could not resist. Oldcutlass is right good advice.
wr1970 is offline
Old May 26th, 2016, 07:24 AM
TripDeuces's Avatar
I love these discussions.
Why do you assume it's heat that is doing it? Is the car running hot? Is this a stock Edelbrock right out of the box or did someone mess with it?
So many questions here.
TripDeuces is offline
Old May 26th, 2016, 02:03 PM
Hookers under Hood
76olds's Avatar
I'm using a 1" phenolic 4 hole spacer with a 1406 edelbrock/edelbrock performer, I had the same issue driving for a distance, stop get gas hard to start and would flood same deal.
Initially I had a 1" open, read the 4 hole gives more low end torque, so I bought the 4 hole chucked the open and its been good, noticable more torque in my opinion. No hard starts when warm.
Although I do have a be cool aluminium rad which helps
It fixed my issue however Tripdeuces make a good point on other issues that can cause this.
Hope this helps
Eric
76olds is offline
tocicar8825
September 21st, 2021 07:10 AM
Daverd
March 10th, 2014 05:46 PM
hurstman1972
July 25th, 2012 06:01 AM
olds 307 and 403
January 11th, 2012 03:39 PM
truthautomatic
Suspension & Handling
February 17th, 2010 07:58 PM
Quick Reply: wood spacers vs. aluminum spacers
