Coolant leak
Old July 9th, 2023, 05:48 PM
Benny23's Avatar
Coolant leak
Ok on the 67 olds 330 we noticed coolant leak when we bought it so I redid the thermostat and gasket it's not leaking as bad but not coming from the gasket or hose can the intake be leaking somewhere any help
Benny23 is offline
Old July 9th, 2023, 07:26 PM
Could b the weep hole in the water pump, but any fitting, hose, frost plug, etc can leak. Look for wet spots on the ground under the engine to help figure out where the leak is.
Fun71 is online now
Old July 10th, 2023, 02:29 AM
Benny23's Avatar
It's on top behind the thermostat on the intake manifold
Benny23 is offline
Old July 10th, 2023, 06:16 AM
I'd suspect that your t-stat housing isn't flat. I assume you have the die cast aluminum version, not the later cast iron version. Remove the housing and flatten the mating surface by sanding it with a sheet of sandpaper on a known flat surface. A piece of glass is ideal, but a metal table top will usually work. I typically use 150 grit wet-or-dry paper for this.
joe_padavano is offline
Old July 10th, 2023, 06:17 AM
harleyrules's Avatar
It could be the thermostat housing itself. It might have developed a tiny pin hole in the casting if it isn't coming from an unseated/tight hose clamp. If the intake manifold is aluminum I've seen them develop a weep leak as well.
harleyrules is offline
Old July 10th, 2023, 06:39 AM
Benny23's Avatar
Can you get new thermostat housing and or intake
Benny23 is offline
Old July 10th, 2023, 07:24 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Yes, you can, don't buy the cheap chrome water necks. What I have found that a second gasket and a RTV like Optimum Grey helps seal. I had to sand the heck out of the factory aluminum water neck and double gasket with RTV in between each to seal. You can also try the 3M sanding and polishing disc's on a drill if the intake is pitted. Good luck.
olds 307 and 403 is offline
Old April 10th, 2024, 07:55 AM
Horsepower's Avatar
If you are going to pull the pump replace it don't waste time with just a gasket.
Horsepower is offline
brotherGood
October 25th, 2023 09:23 AM
Jordans1970OldscutlassS
August 6th, 2019 09:22 AM
highleymd
May 15th, 2018 06:29 AM
sharkey
June 6th, 2013 04:08 PM
Redog
November 9th, 2012 09:41 PM
Quick Reply: Coolant leak
