compression question
Old March 29th, 2024, 05:32 PM
Mr.Classic's Avatar
If I wanted to use the Edelbrock performer cam, performer manifold and 650 4 barrel carb, on a Oldsmobile 350 with 8:1 comperssion what is a cheep way to incress comperssion? The engine has 60,000 original miles on it. Not looking to rebuild it right now,,,, Money is tight right now. It's a 1971 Cutlass with AC.
Mr.Classic is offline
Old March 29th, 2024, 05:58 PM
Phantom Phixer
Charlie Jones's Avatar
There is no " cheep " way to increase compression on an Olds 350.
The compression ratio is determined by the depth of the " dish" in the piston top.
Increasing compression involves replacing the deep dish '71 pistons with shallower dish or even flat tops.
Ten to one or maybe a little more is about the most for 93 octane premium.
Any more than that will require race fuel.
My advice would be to spend your money on a re-build first. Get 10 to one pistons.
Include your new cam in the re-build.
Then when you get some more money, buy the manifold and carb.
That manifold, carb and cam won't do you any good without a substantial increase in compression.
Charlie Jones is offline
Old March 29th, 2024, 06:10 PM
I read one or two of your other posts in which you stated it was mostly a highway car but you wanted a little something extra, or something like that. Here you've stated you're thinking of increasing compression but on the cheap. Everyone has their own range of measuring what cheap equates to, but have you considered dropping in a set of headers?
Vintage Chief is offline
Old March 29th, 2024, 06:34 PM
As said, the 71-72 engines have pistons with a HUGH 25cc dish. There’s really no way to increase compression with those pistons since all the “good” small block heads have the same combustion chamber volume, so you can’t just swap heads and increase compression. And keep in mind that with that low compression it is extremely easy to overcam the engine and create a situation that is worse than before. Too large of a cam will kill low RPM torque and make daily driving unpleasant. The factory cam has a short duration with an early intake closing that helps build cylinder pressure - if you put in a cam with a later intake closing event, the cylinder pressure will drop along with power / torque / driveability.
If you want more power, swap in a 4bbl intake and a QuadraJet carburetor (those are 750 cfm), install dual exhaust (factory specs show 20 hp gain over single exhaust) and ensure everything is tuned to factory specs.
Fun71 is offline
Old March 29th, 2024, 07:45 PM
Mr.Classic's Avatar
Thank you for all your thoughts. I wasn't sure,,, some spoke to me about changing heads to a smaller cc to maybe increase cylinder pressure. I guess for now I will just do the aluminum manifold new carb and HEI? One question though,,,, is a Edelbrock 650 AVS different than a 750 Rochester? What are the pros and cons? Thank you for your time
Old March 29th, 2024, 09:18 PM
As for heads, there aren’t any with smaller combustion chambers than your original 1972 heads. Those should be 7 A (small capital letter). That carb should work well but is smaller than the OEM carb. May not feel any different in daily driving, though. I once had a Holley 600 cdm and after a lot of tuning it ran as well as the original QJet. I eventually put the QJet back on as I got better mileage with it.
Fun71 is offline
Old March 30th, 2024, 02:55 AM
^^^THIS^^^
An OE 4 barrel Quadrjet and intake manifold will have the greatest effect on your butt-dyno.
Olds64 is offline
Old March 30th, 2024, 04:33 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
As said, the big dish pistons leave the compression low. Good part is, there is multiple choices for replacement pistons to boost compression including two in a 4.065" hone to fit size, CP and Mahle, if your block has little wear. A Performer manifold and 650 carb, at least go with the AVS2, will gain nothing and need a wideband to match a factory 4 barrel carb and intake for proper tune. Another option to boost power is full length headers and dual exhaust, should be around 30 HP over single exhaust. Good luck.
olds 307 and 403 is offline
Old March 30th, 2024, 09:51 AM
Rocket Renegade!
Originally Posted by Mr.Classic
Thank you for all your thoughts. I wasn't sure ... some spoke to me about changing heads to a smaller cc to maybe increase cylinder pressure. I guess for now I will just do the aluminum manifold new carb and HEI?
No need for an aluminum manifold, "cheepest" way to go will be to use factory manifold and Q-Jet takeoffs from somebody else who "upgraded". As already pointed out, there is no alternative head you can use to increase cylinder pressure; that is accomplished with pistons. There are also no performance benefits to be had from HEI -- it's largely used just for easier maintenance.
If I was in your situation, I'd just drive it as is for now, and save money for a rebuild that would get me what I really want.
BangScreech4-4-2 is offline
Old March 30th, 2024, 10:09 AM
BillK's Avatar
Money is tight right now..
In that case just leave it alone and enjoy it. None of the things you have mentioned will make any noticeable improvement in performance.
BillK is offline
Old March 30th, 2024, 03:41 PM
Mr.Classic's Avatar
Again thank you all. I know a rebuild is best. Guess I need to just save money and do it right.
Old March 30th, 2024, 04:16 PM
Rocket Renegade!
Now you're thinkin'!
Mr.Classic
December 17th, 2023 07:08 AM
Olds1971
April 25th, 2022 02:32 PM
jrmandryck
March 8th, 2012 06:48 AM
BigTrav
November 6th, 2010 07:36 PM
BigTrav
April 28th, 2010 01:48 PM
Quick Reply: compression question
