1966 Full Size Suspension Upgrades??
Old February 21st, 2010, 12:43 PM
Land Yacht Captain
66ninetyeightls's Avatar
I figure I will be replacing a number of bushings and suspension parts this summer when working on the car. Whenever I do suspension work on cars I like to upgrade the suspension components as much as possible. Mostly bushings etc but am having a hard time finding anything for a 1966 Ninety Eight LS.
Anyone know of companies that make parts for these cars?
66ninetyeightls is offline
Old February 21st, 2010, 04:11 PM
2 '66 98's
bigoldscruiser's Avatar
Check these sites - www.p-s-t.com and www.kanter.com
You can also look for "Just Suspension" but I don't have the site.
bigoldscruiser is offline
Old February 21st, 2010, 04:17 PM
Land Yacht Captain
SO would this kit work for my car??? Were GM full size vehicles pretty much all the same?
http://www.p-s-t.com/pc-4628-618-che...e-1959-70.aspx
Old February 21st, 2010, 06:30 PM
Lt. Buzzkill (ret.)
copper128's Avatar
I bought the front end rebuild kit for my '67 88 from Kanter. It included all new rubber bushings. Most of the bushings are available separately from NAPA, too. Although I'm not sure if I would want to use polyurethane bushings on a Ninety Eight, I believe Energy Suspension makes a poly kit for 65-70 full size Olds.
copper128 is offline
Old February 22nd, 2010, 05:46 AM
I bought PST suspension parts for my 64 98 years ago. If I did it again I would order from Kanter instead. When I bought the kit from PST it was missing a few "hard to find" items. It seems that Kanter has more complete kits. FWIW, I used the rubber instead of the poly bushings.
Olds64 is online now
Old February 22nd, 2010, 07:04 AM
The 61-64 full size cars are different from the 65-70 cars. I believe Energy Suspension lists a bushing kit for the 65-70 D88s. The 98 should use the same kit.
joe_padavano is online now
Old February 22nd, 2010, 09:39 AM
2 '66 98's
I would suggest you don't use Polyurethane. Use the original rubber or upgrade to Polygraphite for a little more durability and no squeeks.
Old February 22nd, 2010, 09:47 AM
Regardless, if one were to rebuild the suspension on their car they should be sure the kit they purchase is complete. I think the PST kit I got for my 64 98 was missing inner tie rod ends and front sway bar to frame bushings. I think the kit sold by Kanter is complete.
Old February 22nd, 2010, 10:07 AM
Land Yacht Captain
Good points by all.
I wish they had new trailing arm kits for the rear suspension as well. Geeze they have kits for Full Size Chevys. Why couldn't Olds just use the same parts!!!!
Old February 23rd, 2010, 06:01 AM
Hmmm... can you get trailing arm kits from Fusicks? This is something that I have never done.
Old February 23rd, 2010, 06:17 AM
"me somebody" site member
aliensatemybuick's Avatar
The 65-70 big cars use the same lower control arms as the A-body cars...not sure about the uppers, but bushings are bushings?
aliensatemybuick is offline
Old February 23rd, 2010, 10:44 AM
Are you sure? Moog lists different lower bushings and ball joints for the A-body and B/C body cars in those years. A-bodies use K5103 ball joint and either K6067 (oval) or K5149 (round) bushings. The B bodies use K5073 ball joint and K5144 bushings.
Old February 23rd, 2010, 10:55 AM
I was responding to the following query about REAR suspension items:
Originally Posted by 66ninetyeightls
Good points by all.
Perhaps if I used Norm's posting technique, there would not have been any confusion.
Old February 23rd, 2010, 11:51 AM
DOH! Sorry for the confusion.
Old February 23rd, 2010, 12:33 PM
Trying to remember member
wmachine's Avatar
Thumbs up
X2 I used Kanter for a full front end kit for my '65 Jetstar 1. Price was excellent, everything was what it should be and no issues with fit.
(And FWIW, what a difference it made!)
wmachine is offline
Old February 23rd, 2010, 01:08 PM
Registered Abuser
Red Delta's Avatar
I used the Kanter kit (upper and lower bushings, ball joints, etc.)for my 66 Delta88. The rubber cracked on the sway bar linkage within a year. I called up Kanter and they sent me a new sway bar kit with no charge. Still look good 7 years later.
Red Delta is offline
Old February 23rd, 2010, 01:14 PM
wmachine's Avatar
Probably wouldn't have cracked if you kept it on all 4 wheels!
But you do bring up a good point: Check them later and don't just presume they are good.
wmachine is offline
71murder
Suspension & Handling
23
August 27th, 2021 01:31 PM
455man
29
February 3rd, 2015 05:11 PM
Takid455
July 20th, 2012 09:40 AM
Stattiolds69
March 22nd, 2011 06:51 PM
BerBer5985
July 9th, 2009 04:58 PM
Quick Reply: 1966 Full Size Suspension Upgrades??
