Power Steering Box
Old April 1st, 2020, 05:57 PM
Stropea1's Avatar
Power Steering Box
Has anyone had the experience of replacing OEM Steering box with a quick ratio steering box? I was thinking about replacing the one on my 1968 Olds 442. Just wanted to know if it’s worth switching to quick ratio.
Stropea1 is offline
Old April 1st, 2020, 06:27 PM
Vincit qui se vincit
vCode442's Avatar
Made the switch recently on my 71 442 and was glad I did. The car feels tighter and drives really well, like turning the clock back about 40 years in regards to steering and road feel.
Dont forget the rag joint should be replaced as well, and the ground strap for the horn needs to be replaced.
Prior to my swap, I searched CO for comments and the only negatives found were some said the quick ratio box felt jittery and almost too responsive - but mine feels right on. Good luck with your decision.
vCode442 is offline
Old April 1st, 2020, 06:48 PM
65Delta's Avatar
I put a Jeep ZJ (Grand Cherokee) box in my '69 and the quicker ratio makes a huge difference. I'd recommend it.
65Delta is offline
Old April 1st, 2020, 09:28 PM
bccan's Avatar
IMO in a car with a sound front end the close ratio box is a great addition. I would put that and a large diameter front sway bar as the 2 best things you can do for steering and handling manners.
bccan is offline
Old April 1st, 2020, 10:03 PM
Olds Omega
exotec's Avatar
Which ratio is thought to be a quick ratio one?
exotec is offline
Old April 2nd, 2020, 06:40 AM
danktx's Avatar
The Jeep is 12.6 to 1 constant ratio box. I just put a Lares 973 on my '67 CS. It is a nice upgrade.
danktx is offline
Old April 2nd, 2020, 08:12 AM
bassinguy's Avatar
I also put the Lares 973 on my 1965 Cutlass. It replaced a manual box. Well worth it Bassinguy
bassinguy is offline
Old April 2nd, 2020, 11:03 AM
therobski's Avatar
STROPEA1, few more ideas. This is on my 64 F-85...Don't know if Lee Engineering is still around but they had a great following for their steering gear boxes..
therobski is offline
Old April 2nd, 2020, 12:15 PM
I completely agree. A week ago I drove my Cutlass on a winding road that is no issue taking at speed in a newer car, just turn the steering wheel maybe 50-60* to take the S curves, but in the Cutlass I had to almost do a hand-over-hand turn, which was a little unsettling. Right then I thought a quick ratio steering box is in my future.
Fun71 is offline
Old April 2nd, 2020, 08:50 PM
'72 Cutlass ragtop
70sgeek's Avatar
Lee is still in business - I put one of their boxes in my '72 last year. Not cheap by any means, especially if you upgrade the bearings and shaft size.
But a great product for sure
https://leepowersteering.com/
70sgeek is offline
Old April 3rd, 2020, 07:52 AM
therobski's Avatar
Along with the B-spindle upgrade, the F-85 steers like a Go-Kart...Glad to hear Lee is still around-not cheap but high quality builds...
Natedawg
Suspension & Handling
March 27th, 2020 09:11 PM
FTolliver
April 15th, 2018 03:59 PM
Robert Kiedrowski
June 10th, 2013 04:40 PM
Joel
March 28th, 2011 09:30 PM
agtw31
15
June 14th, 2010 06:01 AM
Quick Reply: Power Steering Box
