Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
455 motor
Old December 7th, 2009, 02:10 PM
john suder's Avatar
455 motor
Can any body tell me what the horsepower is on a stock 455 is.I have a 455 that I want to build. I dont want it to radical. All I want is a good sound. It has c heads could somebody give me some good sugestions. On what kind of cam to use. And ehat type of pistons to use. I want to run pump gas. I would appreaciate some good suggestions. thanks
john suder is offline
Old December 7th, 2009, 03:12 PM
daves62's Avatar
IM not at all an expert on motors.I would think that you would need to know what the year and model it came from. With a few numbers from the block the olds guru's on here will hook you up.
daves62 is offline
Old December 7th, 2009, 03:27 PM
john suder's Avatar
Dave it is a 74 modle with 70 cranke and 70 heads. So I have been told. I have a set of e and c heads. I have been told that the c heads are the better of the two. I have just started to fool with ols. I can use all the advice that I can get. Thanks
Old December 7th, 2009, 05:09 PM
The "stock" rating could have been anywhere from 250 HP to 400 HP. The differences were due to compression, heads, valve size, carb, advance curve, and single vs. dual exhaust. Note that not only did the rating method change from gross to net HP in the 1971 model year, but the factory ratings were demonstrated to be conservative, at least in the musclecar years. Of course, since your engine is apparently not "stock", we have no way of knowing what the rating is.
joe_padavano is offline
Old December 7th, 2009, 05:20 PM
citcapp's Avatar
Sounds like the engine has already had mods. hard to tell what you have now. Olds 455's used dish pistons to determine compression the deeper the dish the less compression = less hp. heads, intake and exhaust also make a difference. Sound like you need to make a plan. What hp do you want, thats a good place to start
citcapp is offline
Old December 8th, 2009, 02:33 AM
john suder's Avatar
Do you know witch heads are better. The c or e, I have been told that c heads are better . I would just like to have some good ideas. From pepole that deel with ols motors. I am not really consern with how much hp.I just want a good sound. What I was going to do is install 10.1 pistons. But I dont know what cam to use. When I talk to the rebuilders around here. All they want to build it to drag specs. And that is not what I want.
Old December 10th, 2009, 09:33 PM
is Fast Enough ...
mugzilla's Avatar
http://tech.classicoldsmobile.com/95.shtml
mugzilla is offline
Old December 11th, 2009, 06:31 AM
I suggest you find another machinist.
If all you want is a good "sound" then I suggest you rebuild the engine mostly stock. A good flowing exhaust with decent performance mufflers will give you an AWSOME sound with a stock 455.
A good place to start would be to determine your budget and go from there. If you know you have to build the engine on the cheap then you should probably keep it stock. If you have some extra cash to spend then you can determine what aftermarket parts you want to buy. Potential aftermarket parts include a cam, intake manifold, and headers or stock dual exhaust manifolds (all of which would increase your HP considerably). You might also consider installing higher compression pistons (I don't think 10:1 would be good if you want to run on pump gas), a double roller timing chain, and aftermarket oil pump and oil pan.
Olds64 is offline
Old January 17th, 2010, 06:53 AM
Warhead's Avatar
These castings will flow within 5% of each other, as long as the have the same size valves. You will be looking for the set that has 2.072 intake valves in them, to get the best ones.
What are your goals with this car? Really.
Do NOT be concerned with sound so much...you can always buy a stereo.
I like mine quiet.
Jim
Warhead is offline
Old June 14th, 2011, 03:24 PM
1980gutlass's Avatar
Arrow Stock or mostly stock should still sound awesome.
I agree with olds64, I ordered supersonic turbo mufflers for my 80 cutlass when I had the 350 sbo, then replaced it with a 260cid and the 260 even sounded incredible, throaty, but still super quiet. I still want stock 403, with the only mods will be roller lifters, rockers and maybe high volume oil pump, but hope my mufflers are still worth keeping.
1980gutlass is offline
BLACKCADDY
June 2nd, 2015 09:38 AM
442b
October 24th, 2011 07:38 PM
dp442
February 15th, 2011 04:22 PM
ctrain22
May 20th, 2009 11:02 PM
Quick Reply: 455 motor
