'69 Toronado...extremely warm front wheel?
Old June 14th, 2017, 11:18 AM
Ronschwartzsr's Avatar
Question '69 Toronado...extremely warm front wheel?
My '69 Toronado is equipped with four wheel power "drum' brakes. While the car continued to stop reasonably well, I could feel a slight brake drag after coming off the pedal and I was noticing that the right front wheel seemed to be really warm (the wheel cover was hot to the touch..ouch). I assumed that was where I was getting some brake drag. I'm not getting any younger so I decided to not dig into the brakes myself. My local mechanic replaced the shoes, hardware, and cylinders on all four corners and had the drums turned.
The result:
My car brakes beautifully...really smooth and straight....no drag or pull in any direction!! I like it....
but, the right front wheel still seems to get overly warm! I was thinking perhaps a bearing problem but my mechanic doesn't think so...no bearing noise, etc.
Any thoughts or experience about what the issue might be? Your feed back will be appreciated!
Ron S
Crown Point, IN
Ronschwartzsr is offline
Old June 14th, 2017, 11:26 AM
Ron, can you detect a ticking sound as the car moves? A bad bearing would also result in slop in the wheel. Try to wiggle the wheel up and down or side to side with the car lifted and the wheel suspended off of the ground. Make sure you use safety stands.
Olds64 is offline
Old June 21st, 2017, 09:56 AM
What is overly warm, and how do you measure that? Steel wheels hold a lot of heat even from the sun and Toro wheels are very heavy steel.
Allan R is offline
Old June 30th, 2017, 02:15 PM
Thanks for the responses.......i seemed to have solved the problem by replacing the front brake hose. It seems it must have had a slight interior
separation that didn't allow for a complete release after applying the brakes. So far, so good.
FYI...when I described warm, I should have said it was so hot you could not touch the wheel cover!
Old June 30th, 2017, 02:20 PM
Thanks for following up.
oldcutlass is offline
69'442
September 23rd, 2012 12:47 PM
69'442
15
August 2nd, 2012 06:55 PM
erudek
October 4th, 2010 06:25 PM
rustyold66
August 7th, 2008 07:52 PM
beanship
Bravada
July 10th, 2007 12:36 PM
Quick Reply: '69 Toronado...extremely warm front wheel?
