Fusible link '66 toronado
As oldcutlass said, there does not appear to be a fusible link in a '66 Toronado. In looking through the electrical section of the '66 chassis service manual for the Toronado, I can find no mention of a fusible link.
Here's a portion of the '66 Toro wiring diagram from the '66 service manual. The junction block is shown at left, and none of the wires coming off of it pass through a fusible link.
Here's the '66 Toro fuse usage chart. Nothing shows a fusible link, including the heavy duty power draws shown at the bottom (headlights, A/C, etc.). Each has its own protective circuit breaker in various locations.
Check: Wiring connections at the coil, then coil itself. If those pass muster I think it will be in the distributor. My 69 Toro used to do that exact same thing; upon pulling the distributor I found a poor connection on the coil trigger wire that the advance plate would sometimes kill completely.
May be time for a distributor rebuild.
