Jacking points on '69 Toronado?
I bought a Quick Jack, and when I position it under my '69 Toro, it seems like it's very front heavy and is not stable on the jacks. I have the jacks placed under the frame rail that runs alongside the rocker panels of the car. Even with the Quick Jack placed as far as it can go towards the front, it is still very front heavy and unstable. What are the best points to lift the car with?
I don't understand this......you're lifting the car using the same jack points as normal. When the quick jack settles on the locks, it should be the same as if you had 4x jack stands under those points. Using 4x jack stands, 70% of the weight is still going to be over the front wheels.
