Which Lubricant for 1967 Toro Differential?
Gents: Need to check and possibly change/refill the lubricant for a 1967 Toro differential, I will appreciate any recommendation on which type to use. Regards. Raul.
Yes, I believe that is correct. I would have to check a receipt, but I recall NAPA had it and the CSM states Non-Foaming is recommended.
He is in Argentina. His post is over a month old he probably figured it out by now. Worthy of a reply and archive value. Thanks Oldsmobuser
The 1967 Oldsmobile Chassis Service Manual says that for the final drive on the Toronado use gear lubricant part number 1050015 or equivalent. Fill to level with plug hole in cover.
If it is a positive traction rear end you need to use the GM additive with a traditional lube which was generally 90 weight.
1930-2007 Chevrolet Camaro Parts | G7103 | GM Posi Differential Fluid (classicindustries.com)
Well Gents Tx for replying after all, I can only find here an AC DELCO 85w95 which I am plannign to use, if someone has any obervation on this please advise else I will go for it. Amazing picture of the original oil!
