Noob here- Need help with VIN for getting title
Old June 8th, 2021, 11:11 AM
gpatterson83's Avatar
Hi All,
I'm working on a deal to pick up a '66 Toro... my first restoration job - very excited!
Car has no title, but here's the nameplate under the hood. Can anyone help me decipher where the VIN is? I'm going to pay a service search it for me to see if I can get a title. Also, if you would, let me know if
66 Toro
there's any other useful or neat information within the nameplate. Thank you!
gpatterson83 is offline
Old June 8th, 2021, 11:16 AM
Oldsmaniac's Avatar
The VIN number is on the driver's side door hinge pillar, the Trim tag is what you have pictured, there is no vin number there.... getting a Title can be difficult, you maybe going down a road with a dead end.
Oldsmaniac is offline
Old June 8th, 2021, 11:20 AM
Run to Rund's Avatar
I would not put a dime into restoration until I have a title.
Run to Rund is offline
Old June 8th, 2021, 11:22 AM
Understood, thank you. I'll see if I can go back and get the VIN. Thanks.
Old June 8th, 2021, 11:36 AM
Hey if nothing else, is there a market for a running 396021F ? Not sure how desirable it is...
Old June 8th, 2021, 11:39 AM
The VIN will be 13 characters and will start 396876Mxxxxxx.
That car was built the fourth week of Jan, 1966 in Lansing, MI. It was originally Champagne Mist upper and lower body color, with a fawn (antique parchment) strato bench interior. It came with tinted glass, power windows, power seat, A/C, rear seat speaker, and deluxe seat belts. I can't find a reference for the 3P code anywhere, however. That one has me stumped.
joe_padavano is offline
Old June 8th, 2021, 11:43 AM
Oldsmaniac's Avatar
The original engine would be a 425 D block...an F block is a 455
Old June 8th, 2021, 11:44 AM
That's so cool! I wish I knew how to read that.
Old June 8th, 2021, 11:49 AM
I follow you completely. Before going to look at the car I read this and found 369021F by the water pump heads 394548 and 394(646) (i think, it's hard to read). Motor is red so I know off the bat its the wrong motor for a Toro.
https://classicoldsmobile.com/forums...cation-112127/
Old June 8th, 2021, 07:54 PM
Oldsdruid
rocketraider's Avatar
Don't be surprised if you find the VIN plate reads 9487 and not 9687. 9687 designates a Deluxe optioned car on the data plate. 9487 is Toronado generic car code.
rocketraider is offline
Old June 9th, 2021, 05:02 AM
Actually, Glenn, according to the 1966 CSM, the VINs were different for 94xx and 96xx series cars.
Old June 9th, 2021, 05:27 AM
Olds Fanatic
69 Hurst's Avatar
I thought Toro motors were red...?
69 Hurst is offline
Old June 9th, 2021, 05:29 AM
No. Pale metallic blue for 1966-69. RWD 425/455 motors were red for 1965-69.
Old June 9th, 2021, 06:58 AM
BackInTheGame's Avatar
Same here! I've got a '68 455, second or third hand, and was told it came from a Toro. It was in a Ford truck when I bought it. It is red from the factory. Though not a sure fire indicator, the VIN derivative on it is 38M60094(5?). The last digit was not stamped very well. It has a "K" intake manifold. I know this is not Gospel, but the old Oldsmobile FAQ site has this line:K 398664 '68-'69 455 Toro. It also has a Toro short-base aircleaner.
BackInTheGame is offline
Old June 9th, 2021, 07:11 AM
All 1966-69 Toro motors are pale metallic blue. The fact that this 455 was in a Ford truck tells you that it has been messed with. 398664 is a Toro intake, but how do you know it was born on that motor? And how do you know that the red is original paint?
This is a 1968 Toro motor in it's original habitat.
Old June 9th, 2021, 07:18 AM
And just to settle this once and for all, this is from the factory Engine Assembly Manual. This is from 1969.
Old June 9th, 2021, 09:04 AM
Thanks, Joe; still learning, every day! I'm pretty sure the red is original, though it was on pretty thick on the VIN pad. I scraped off several coats and never found any different colors.
Last edited by BackInTheGame; June 9th, 2021 at 09:16 AM. Reason: added info about color/paint
Old June 9th, 2021, 10:04 AM
But if the engine had been hot tanked, there would have been no prior paint left on it when it was painted red.
Don Bunnell
May 8th, 2020 02:15 PM
starr88
January 24th, 2013 12:43 PM
mike623
April 2nd, 2011 06:58 PM
shaks 442 clone
April 9th, 2007 03:19 PM
olds53rocket
December 22nd, 2006 05:46 PM
Quick Reply: Noob here- Need help with VIN for getting title
