Parting out 1969 Toronado
Straight body, minor surface rust, sat in a barn for ~20yrs.
All glass intact.
Running/driving car, but needs far too much work (entire floorpan full of holes, etc). to keep.
Might wait until spring for the bigger things, but thought I'd get a head start on some of the smaller things if I have them.
Will provide pictures of specific things if requested.
All glass intact.
Although they would probably be the last things I'd sell, as I still need to move it around now & then, and don't have anything else to put on it.
It's the same as the one in this picture, but green:
http://forums.aaca.org/attachments/f...1-dcp_1340.jpg
The outer wheel itself is not good, cracked, small pieces missing.
The horn pad is good.
turn bezel
I need a turn/cornering light bezel/assembly for the left side. It isn't in the grill. it's in the fender. It is a combination turn signal (amber?) and turning/cornering light (clear). sdcarguy
If you have or can get some Chevy 1/2 ton 5 lug wheels they will bolt right on. That is what I have on my Toro right now. Sold the wheels to a guy on this site from Sweden.
(Everything was off the car when I got it, previous owner was going to prep it for paint before he abandoned it)
mirror
Do you have the drivers side mirror, and which one is it?
All glass intact.
All glass intact.
The front bezel I need is pretty easy to spot. If the hole in the fender is around 16 inches long, I'll wait for the spring thaw. If it's only about 7 inches. you don't have one. Thanks for your help.
Believe me, I've had the ones on my 69 apart enough to know. I had to take them apart and rebuild them due to bad springs and socket corrosion.
Well, thank you for that information. I was under the impression that the 69 and 70 were the same. No wonder I haven't been able to locate one. I'll leave this guy alone and go bother someone new.
SD drop me a line at dead@mchsi.com I believe you have the combo marker/cornering light. I'll take a pic of the pair that I have and make sure thats the part you need. Regards Pat
2. No trunk light.
3. I have two sets of dash gauges!
They both look nice, nothing broken.
(Cluster 1, still in car)
(Second cluster)
Great- could i telephone you? I am a new member and not sure of the protocols. If I am not breaking the rules could you reply to me at cumming2@telus.net. regards
Can you get into the trunk? I am looking for the small zig zag shaped bracket for the jack hold-down. It should be on the drivers side of the trunk and is held down by a wing nut.
Got all 4, very nice condition under all that dust.
I believe this is what you were asking for?
This harness?
This harness?
All glass intact.
All glass intact.
I'm still interested
The parts
4 hub caps
the window switches and I'll need both harnesses for the switch gear for both doors. windows and door locks. Do you have a rear view mirror as well?
Email me with the prices
Steve
4 hub caps
Steve
#33
steering wheel
The horn pad is good.[/QUOTE]
Is the steering wheel sold?
#34
Toronado Right Tail Light Lens
I am looking for the right tail light lens for a 69 Toronado. Do you have one that you would be willing to sell?
Tom Saxton
707-536-7554 please call or text me
Tom Saxton
Greg McDonnell
February 28th, 2009 06:54 PM
