q jet fuel filter question
Old February 7th, 2021, 10:20 AM
sgolds's Avatar
I accidentally left off the spring after putting the fuel filter in, can I leave it that way, or do i need to put the spring back in?
sgolds is offline
Old February 7th, 2021, 10:39 AM
The spring is what holds the filter against one end of the cavity, to force the fuel to go through it instead of around it. Yeah, you need to put it back in.
joe_padavano is offline
Old February 7th, 2021, 10:41 AM
Oldsmaniac's Avatar
And don't forget the thin paper gasket. Sometimes they are attached to the filter and sometimes not.
Oldsmaniac is offline
Old February 7th, 2021, 10:47 AM
I can't say that I've ever seen them not attached. The better filters have a check valve with an integral seal instead of the gasket.
Old February 7th, 2021, 10:53 AM
Any love for the sintered brass ones?
Koda is offline
Old February 7th, 2021, 10:58 AM
Oldsmaniac's Avatar
Thats all I use on thy 66-67 quadrajets, they take the short filter.
Old February 7th, 2021, 01:20 PM
sgolds's Avatar
So, basically the filter is not filtering without the spring?
sgolds is offline
Old February 7th, 2021, 02:06 PM
Oldsdruid
rocketraider's Avatar
Can you still get those?
If the filter is flopping around loose in the inlet housing gasoline is bypassing it. Recommend correcting the spring issue and then install an inline filter in the rubber fuel pump suction line, between fuel tank and pump. By doing that you should rarely, if ever, have to disturb your QJet's filter housing again. The more you fool with that potmetal the greater the chance of creating a leak.
rocketraider is online now
Old February 7th, 2021, 02:15 PM
That's what I said in Post #2.
Old February 7th, 2021, 02:18 PM
This has the added benefit of keeping crud out of the pump check valves, which helps them live longer.
Old February 7th, 2021, 03:36 PM
I like the Wix 33033, which is metal, 3/8" inlet and outlet, 20 micron filter media, and about $3.26 at RockAuto. Yeah, plastic is fine on the suction side, but I still like the Wix.
Old February 7th, 2021, 03:40 PM
Oldsdruid
One of those will work fine. Reminder that Olds have 3/8" fuel lines. Good excuse to replace that old rubber fuel line while you're at it.
I like to use the OE type spring clamps like in Joe's pic on these. Available in Dorman/Motormite HELP aisle if they don't come with the filter and just looks better IMO. Never been a fan of screw-type hose clamps.
Old February 8th, 2021, 12:17 AM
HighwayStar 442's Avatar
If you have a return line WIX Filters - 33040, cheap to buy. Installed where the charcoal canister was. Have an low pressure fuel pump in gas tank.
HighwayStar 442 is offline
Old February 11th, 2021, 01:02 PM
sgolds's Avatar
Unfortunately that was already the issue, I couldn't get it to stop leaking at the inlet, finally tightened it enough not to leak, but then realized I forgot the confounded spring 🤬🤬
sgolds is offline
Old February 11th, 2021, 01:03 PM
sgolds's Avatar
Just curious, has anyone used an aftermarket carb such as Edelbrock or Holley on a Toronado?
It would be nice to not have to worry about those threads leaking etc
sgolds is offline
Old February 11th, 2021, 04:21 PM
Oldsdruid
Did the fuel inlet have a fiber or nylon gasket on the large end? It fits around a raised lip on the carb end and helps seal the filter housing so you don't have to overtighten it and risk stripping it. MIA in a lot of cases.
Olds used the side inlet QuadraJet only in 1966 and 1967 but Chevrolets used them forever, so a Chev carb would probably work better than an Edelbrock or Holley. Toronados had their own specific choke linkage which complicates any swap but find a Chev carb that has same type choke as your Toronado.
An alternative is to send your carb to Greg Kalkhoff for rebuild to specs and to have throttle shafts rebushed and the fuel inlet heli-coiled if needed. www.sparkyscarbs.com
Old February 11th, 2021, 04:32 PM
Restorer
425HP409's Avatar
I'm suspecting all I need is a simple in-line fuel filter - simple & easy to replace - with the correct rubber in-line fuel sized 1/4", 5/16", 3/8" or whatever inlet/outlet. Something on the order of a basic fuel filter I suspect?
I use the Napa clear ones like this on all my cars so that I can visually check them for contamination. To keep the under hood clean I put them near the tank.
425HP409 is offline
Old February 11th, 2021, 09:17 PM
sgolds's Avatar
Mine had a nylon gasket, we tried to use a metal one but it leaked, then the nylon one was bent out of shape after removal so neither worked. We ended up putting both together and tightened a lot and it stopped
sgolds is offline
jpc647
November 2nd, 2014 03:40 PM
Cutdawg78
April 23rd, 2012 06:13 PM
Thomas Simcich
September 10th, 2011 06:18 AM
BStone
August 13th, 2011 06:16 AM
RussTad
May 28th, 2008 03:16 PM
Quick Reply: q jet fuel filter question
