The saga continues
Old November 5th, 2023, 10:24 AM
Jetmek's Avatar
The saga continues
So as i expected the axles wont clear lower cont arm with no weight on it so i had to bust upper ball joints. Kinda glad i did. Did someone weld them in or torch cut tops off for axle clearance? Jus keeps getting better
Jetmek is offline
Old November 5th, 2023, 11:46 AM
That control arm is toast. Good luck finding another.
Olds64 is offline
Old November 5th, 2023, 06:15 PM
2blu442's Avatar
I'm on the other side of the country. But I've got some Toro stuff. What year are you working on? I know I've got a set of 1967 A-arms that are loose. John
2blu442 is offline
Old November 5th, 2023, 06:36 PM
True hackers. How people hack stuff together to sell it knowing the crap you are putting out there?? You have no soul.
Hopefully someone here can help.
no1oldsfan is offline
Old November 9th, 2023, 02:40 PM
2blu442's Avatar
I've got one that's in decent shape. But I'm in Oregon and the OP is in New York. I'll offer mine at a price I'd want to pay, which I consider on the low range but shipping may be more than the purchase price. If anyone closer has one in good shape go ahead and offer it to him.
Then so all can understand what happened to his, the factory riveted these on the sides of the ball joint and it looks like the bottom as well. Or the top, so it won't interfere with the axles.
2blu442 is offline
Old November 9th, 2023, 02:55 PM
Jetmek's Avatar
thank you for your trouble. John dorsey is sending one. As to cause of failure, mine has replacemnt bolt on ball joints. Also drive axles had been replaced and it appears the top bolt torched off for clearance. Ill have to come up with a fix when i get to that point. Dont know how to secure axle in a lathe to cut it down so we shall see. Thanks again for your offer
Jetmek is offline
Old November 9th, 2023, 03:04 PM
2blu442's Avatar
Hopefully the replacement ball joint won't have a bolt head that would interfere with the axle. I would be cautious about turning down the axle to clear the ball joint fastener. I suspect there's other members here who've changed out the ball joints and may be able to provide some advice on how best to do it.
2blu442 is offline
Old November 9th, 2023, 03:21 PM
ourkid2000's Avatar
I just received a full set of replacement ball joints for my 66' from Fusick. I'll take some pictures of them and post em here. The replacement ball joints show bolts on the install in the CSM so I think you should be just fine.
Straight from the 66' Toro CSM
ourkid2000 is offline
Old November 18th, 2023, 08:13 AM
Jetmek's Avatar
Cleaning the caked on grease since i was jetwashing some model a parts today
Jetmek is offline
Gauchobyte
October 24th, 2022 07:28 AM
matt69olds
November 1st, 2019 07:36 AM
cdrod
Suspension & Handling
April 8th, 2014 10:26 AM
Seff
June 30th, 2013 05:11 PM
805cut
July 22nd, 2012 05:53 PM
Quick Reply: The saga continues
