Water Outlet & Thermostat leakage
Old August 25th, 2006, 02:23 PM
155thINF's Avatar
I just replaced my thermostat and water outlet with new seals on my 1990 Oldsmobile Toronado and it has a slow seeping leak I was wondering how to stop the leak the water outlet has only one factoiry screw and that i think is the problem. Would a little silicone gasket maker solve this problem? Any suggestions would be appreciated!!!
155thINF is offline
Old August 25th, 2006, 05:30 PM
goodwrench1984's Avatar
Thermostat hsg leak
get a nice new "O" ring from a GM dealer and make sure the housing and the hole in the intake are clean of debri like that hard white substance. Then lube the O ring with some grease or vasaline and put in place then tighten screw. Just make sure that you seat the housing by hand before you tighten the bolt. That should do it.
Chris
goodwrench1984 is offline
sixtyfour
March 26th, 2014 06:00 AM
jensenracing77
February 11th, 2014 03:44 PM
67 Cutlass Freak
September 19th, 2013 08:56 PM
louie
September 15th, 2013 07:43 AM
72RocketPower
November 22nd, 2004 02:02 PM
Quick Reply: Water Outlet & Thermostat leakage
