1935 3 speed to 4 speed swap. HELP!
Old February 7th, 2008, 05:02 AM
Green Bay Olds
ilde's Avatar
I want to swap the original 3 speed trans out of my 1935 Olds to a 4 or 5 speed trans. Does anyone have any info on doing this, or any ideas? Would I need to change out the bell housing completely or can I adapt the newer trans to the existing bell? Any help and ideas will be appreciated. Thank you, Dan.
ilde is offline
Old February 7th, 2008, 05:27 AM
Past Administrator
Oldsguy's Avatar
Dan, is the rest of the drive train stock? Engine and rear? If so, you might find some help on this subject over at the HAMB as there are lots of older cars (not just Olds though) over there. But good luck.
http://www.jalopyjournal.com/forum/
Oldsguy is offline
Old February 7th, 2008, 10:21 AM
You might check out the following websites. They do conversions for transmissions on older cars.
http://www.transmissionadapters.com/index.htm
http://www.forwhatyouneed.com/tansonp1.html
Olds64 is offline
kds 69 442
Brakes/Hydraulic Systems
September 4th, 2013 07:34 PM
ilde
November 21st, 2010 05:39 PM
jimrockford
October 29th, 2009 06:51 AM
chevyracing1993
May 3rd, 2008 01:24 PM
TECH9TWISTA
February 8th, 2007 09:41 AM
Quick Reply: 1935 3 speed to 4 speed swap. HELP!
