1974 z-bar setup
Old December 5th, 2004, 08:43 AM
anthonysteve38's Avatar
Post
Anybody got any info on a z-bar setup for a manual trans. for a 1974 hurst. The car came with the motor out and the z-bar was just hangin there. I dont know if a setup from a 72 or so will work or not. The bracket mounted to the frame also looks a little fishy. Companies like original parts group only carry parts from 64 to 72. any pics or info would be gladly appreciated.
anthonysteve38 is offline
Old December 5th, 2004, 11:35 PM
mike88's Avatar
Post
Anthony,when you say 74 hurst, do you mean Hurst/Olds, or hurst manual trans. shifter. If it is an H/O, none came with manual trans., all were automatic w/ dualgate shifter. I'm pretty sure that a stick in a 74 is even rarer than a 73. Some 76 and 77s came with a stick, but they were behind the 260 engine. Would love to see some pics of the setup.
mike88 is offline
Old December 11th, 2004, 11:47 AM
Post
Well here's the deal: I purchased a 1974 supreme from texas that was in excillente contition. A whole garage of olds parts came with it. A 67 toro 425, a 455, 2 350's, turbo 400, manual flywheels, etc., etc. (You get the picture). Also there's a so called 1974 Hurst Olds in a garage here in Ohio, also comes with the deal. $750.00 bucks. Now, the so called 74 Hurst is not actually a Hurst, according to the numbers. However somebody must have stole a bunch of parts off of one and tried to make one. Now one thing I do know is it has the 74 H/O hood with the louvers, all of the interior parts. I dont know if you have ever seen a manual console from one of these cars but it's definately a 4sp console. Manual column and there is no R N D 1 2 on the console, column, or the dash guages. All set up for a 4sp. Here's what I think I've got: A 74 cutlass that came with a 4sp and somebody hat a H/O donor car, maybe wrecked, and borrowed the parts. It did come from the factory with a 455. I'll try to send you some pics.
helm42
July 12th, 2008 10:57 AM
Eightupman
Brakes/Hydraulic Systems
July 12th, 2007 12:45 PM
Kennybill
May 10th, 2007 12:52 PM
snowri
March 29th, 2006 04:36 AM
Kennybill
January 12th, 2006 05:31 AM
Quick Reply: 1974 z-bar setup
