200 R4 question
Old November 27th, 2010, 06:13 AM
Resident Eskie
snowballs442's Avatar
200 R4 question
I got a stock 200 R4 and am putting cooler on trans. I live in a climate that does not get cold in winter. Can I put the cooler after the stock cooler? Or is that a no no?
snowballs442 is offline
Old November 27th, 2010, 06:23 AM
Lady72nRob71's Avatar
Out of logic, I think that would be the better place to put it for maximum cooling in hot areas.
Lady72nRob71 is offline
Old December 28th, 2010, 06:24 AM
'87 Delta 88 Royale
rustyroger's Avatar
How I did it.
I put a cooler on my car this year, my local trans shop recommended I install it so the hot fluid goes through the aftermarket cooler then back through the original heat exchanger in the coolant radiator.
He recomended doing it this way to avoid overcooling the trans fluid, don't forget trans fluid just like all lubricants works best at the right temperature and this was a good compromise if I didn't want to go to the trouble & expense of fitting a thermostat as well.
rustyroger is offline
davoaz
August 16th, 2014 09:03 AM
KeithsCustCutlass
October 12th, 2011 10:47 AM
The Stickman
January 21st, 2009 07:36 AM
Olds64
January 29th, 2008 06:17 AM
J-(Chicago)
Drivetrain/Differentials
December 11th, 2007 07:08 PM
Quick Reply: 200 R4 question
