62 Starfire kick down ?
Working on a 1962 Starfire. Solid car running .Many parts in the trunk. Did not find a rod or cable for a kick down so I don't know if it supposed to have one. There is a small arm on the left side of trans that moves back and forth with nothing attached to it. For some reason I can not find a picture to identify, even my old Motors manual.
The TV rod on a 62 is a 2 piece rod, has a threaded yoke on the engine end and a pin that has a cotter pin that locates on the lever of the TV valve. The 63/64 will fit and work and is a one piece rod. Setting the rod is an experience in itself as I'm trying to reset mine on my 63 convertible. Driving without the rod will damage the transmission.
Steve
Steve
